Thinking of Installing Baker compensator - Road Glide Forums
post #1 of 4 (permalink) Old 10-14-2016, 01:28 PM Thread Starter
Question Thinking of Installing Baker compensator
After speaking with Mark over at Baker today. He told me that the Baker Compensator was only good for builds up to 130 torque. So for those that have the Baker Compensater installed, what kind of hp and tq are you running? I have 128.26 hp and 133.75 tq. Mark told me I could try to run this but they would not warranty it if anything happens! He told me to use a 34 tooth solid sprocket in lieu of the baker compensator. I see where a few fellow CVO's are using it on here and have limited miles (5000) with no issues, and a few that have had it installed and have had issues! Any thoughts?
Catbalou is offline
post #2 of 4 (permalink) Old 10-14-2016, 03:05 PM
JayKS's Avatar
I'm at 138hp/136tq and I went through a Baker compensator in about 6-8k miles. Comp sprocket bolt backed out on me. I'm now running an Evolution Industries solid sprocket.
JayKS is offline
post #3 of 4 (permalink) Old 10-14-2016, 08:08 PM Thread Starter
Jayks, how does the single sprocket handle at low speeds? Say is there any issues with slow speed parking lot or stop light vibration or crank failure? I too have the evolution clutch diamond terminator. I did not do any crank update when i did my gmr 113 build. Just curious what effect the single sprocket change is working? Thank you for your reply.
Catbalou is offline
post #4 of 4 (permalink) Old 10-15-2016, 07:52 AM
JayKS's Avatar
It's slightly 'twitchy' at very low speeds, but it's easily managed.
I'm running an Evo 34 tooth (stock size) sprocket; an Evo 49 tooth clutch basket w/diamond terminator clutch.
I'm also running an S&S crank on a 124" build. I've been warned against running a solid sprocket on a stock crank, but I have no direct experience with that.
Sent from my iPad using Tapatalk HD
JayKS is offline
Baker compensator ordered Tour Rider Tech Area 8 10-10-2016 08:19 AM
Baker Compensator Kit PN #630 D - 67 Straitline Engine Related 6 11-17-2015 11:42 AM
Baker Compensator and attitude adjuster have arrived*** HogPro *General Road Glide Discussions/Pictures 18 11-10-2015 09:31 PM
Baker Drivetrain Compensator Hullhorr Engine Related 11 07-28-2015 09:39 PM
Baker Compensator anyone? HogPro *General Road Glide Discussions/Pictures 4 03-17-2015 10:40 PM
