ABS Question - Road Glide Forums
 2Likes
  • 1 Post By twowheeladdict
  • 1 Post By skratch
post #1 of 6 (permalink) Old 10-17-2016, 04:23 PM Thread Starter
ABS Question
The other day I was practicing hard braking stops at speed, which of course engages the ABS (2009 RG). I've been using the rear brake almost exclusively for this so far; still working my way up to incorporating the front brake.
Every time ABS engages during these drills - and on the occassions when it's not a drill - there is a very loud, repeated clank/clunk that comes from the rear brake while the bike is coming to a stop. I would say there are probably half a dozen clunks or so during a stop from 35 mph.
Is this normal?? Also, for those that have an understanding of how ABS works, am I causing any long-term damage - or degradation of effectiveness - by engaging ABS repeatedly during drills?
Dan23113 is offline
post #2 of 6 (permalink) Old 10-17-2016, 05:10 PM
twowheeladdict's Avatar
Other than wearing out your pads and tires quicker than normal, I don't know of any ill effect.
How many miles on the bike, and when was the brake system last serviced?
Also, why are you not using the front brake? That is 70 percent of your stopping power. If you don't want to experience how the abs feels until you grab it in an emergency, you might want to rethink that.
madmat likes this.
twowheeladdict is offline
post #3 of 6 (permalink) Old 10-17-2016, 05:23 PM
Dragon Dude's Avatar
My 13 does the same thing for some reason at times. The clunk or clank on mine feels like it comes from under my rear brake pedal some where. It only does it on mine on a hard stop unless i have my clutch pulled in then it doesn't do it, so i am curious as to what it is also.
Dragon Dude is offline
post #4 of 6 (permalink) Old 10-17-2016, 11:12 PM
skratch's Avatar
it is the abs module releasing and re-applying pressure.
the system is working like it's supposed to.
now, about not using the front brake......
Stray Mutt likes this.
skratch is offline
post #5 of 6 (permalink) Old 10-18-2016, 05:56 AM
gorillaman's Avatar
Listen and feel the ABS activate in your car or truck... its just as bad.
2016 FLTRU Vivid Black
gorillaman is offline
post #6 of 6 (permalink) Old 10-18-2016, 08:57 AM Thread Starter
Glad to hear the clunking is both normal and not damaging anything.
That's a fair point on the front brake, I need to work on that.
Dan23113 is offline
Can I put a Abs rear wheel on a non ABS rear? Louster47 Wheels and Tires 10 03-24-2013 10:05 PM
Question: Mounting ABS Wheels On A Non-ABS Bike MikeMan Wheels and Tires 10 02-22-2013 03:48 PM
non-abs wheel on abs bike W_D_R Wheels and Tires 1 11-24-2012 07:54 PM
To ABS or not to ABS apexlocator Safety Area 33 07-06-2012 09:17 PM
Bonding ABS to ABS or fiberglass? Monkeyman Paint & Bodywork Section 8 04-28-2012 02:16 PM
