Clutch release ramp/ball assembly - Road Glide Forums
 2Likes
  • 1 Post By EODHOG
  • 1 Post By JayKS
post #1 of 7 (permalink) Old 11-07-2016, 02:55 PM Thread Starter
JayKS's Avatar
Hey all. I need a little advice from my mechanic friends. A few days ago I was riding and my clutch started feeling strange. A little bit later, when I pulled in the clutch lever, it went to the grip and the cable 'retainer' (for lack of a better word) popped out of the lever housing.
My first thought was that I'd snapped a clutch cable. However, the clutch didn't act like that. In fact, it was sort of half engaged. I could start and stop the bike. I could even shift between gears a bit.The clutch was slipping so much that I could barely make 20mph. I babied it home, maybe 4-5 miles. Long story short, I took it apart today and I found that one of the ball bearings in the ball/ramp assy had popped out of place.
I disassembled and cleaned everything. I found a little bit of pitting on one of the inner ramps (see pics). So, I guess I'll replace the inner and outer ramp assemblies (about $30 worth of parts). My question is, has anyone seen this happen? Any opinions on whether I should be worried about anything else, or just reassemble, adjust and move on?
JayKS is online now
post #2 of 7 (permalink) Old 11-07-2016, 11:30 PM
JacktheBagger's Avatar
I have had it happen as well , never figured why , otherwise , it can happen when you change the cable out ..
2011 Ultra
JacktheBagger is online now
post #3 of 7 (permalink) Old 11-08-2016, 07:11 AM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
The Same But Different
I had something similar but different happen. While riding around I pulled the clutch in at a stoplight and I felt something like what you described. I nearly lost all clutch control by the next light so I limped it home since that was where I was headed anyway. It wound up being the clutch throw-out bearing, after putting everything back together with no change in my problem. Turns out my throw-out bearing failed and came apart, letting the balls fall out of the ramps. I replaced the bearing and it all worked as it was supposed to.
I would put it back together and make sure it works first, or better yet, inspect the bearing BEFORE putting it back together. The balls should NOT fall out of the ramps for no reason. Something else is going on, IMO of course.
Stick_FSMC likes this.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #4 of 7 (permalink) Old 11-08-2016, 09:17 AM
That little smooth looking oclusion looks like a little fawl in the castig and being more of a pit may not affect
reds4 is offline
post #5 of 7 (permalink) Old 11-08-2016, 03:11 PM Thread Starter
JayKS's Avatar
Thanks for the responses guys, especially EODHOG. Your post got me thinking. I'm running a 124" motor, along with an Evolution Diamond Terminator clutch with heavy duty springs (Red). I'm sure that puts extra pressure on that throwout bearing.
I looked into it further and Baker makes a heavy duty throwout bearing kit. It's got a bigger bearing, larger thrust washers (97% more surface area, they say). It also comes with the balls and ramps, etc. I've got one on the way and hope to install it this weekend.
Thanks again. -J
JayKS is online now
post #6 of 7 (permalink) Old 11-08-2016, 03:15 PM
James's Avatar
Thanks again. -J
So the conclusion is to throw bigger balls at it?
James is offline
post #7 of 7 (permalink) Old 11-08-2016, 03:35 PM Thread Starter
JayKS's Avatar
Hey, my balls were plenty big. It was just a matter of keeping them in place.
James likes this.
JayKS is online now
Aluminum RNR enclosed trailer with ramp door - 16' plus v-nose 1drwfan Sold 3 04-18-2014 04:53 PM
Ramp length Witt19 *General Road Glide Discussions/Pictures 22 02-01-2014 07:39 PM
Ramp for loading your Glide into pickup truck Shark daddy General Off-Topic Discussions 21 04-13-2012 03:38 PM
Trailer ramp musicman8120 *General Road Glide Discussions/Pictures 3 03-26-2012 11:16 AM
Cruiser Ramp Pickup Motorcycle Loader Florida Cracker General Off-Topic Discussions 1 12-14-2010 07:09 PM
