Specs for replacement Derby cover bolts - Road Glide Forums
post #1 of 11 (permalink) Old 02-23-2013, 02:32 PM Thread Starter
StriderJim's Avatar
I read somewhere in the forum the suggestion to replace the clutch cover bolts with hex head stainless bolts. This seems like a good idea.
Can anyone tell me what the specs for the bolts should be? That's probably not a hardware item, and might need to be ordered.
More generally, is there somewhere that lists the specs for all the fasterners used on a Harley?
Many thanks,
StriderJim.....................Blog:
StriderJim is offline
post #2 of 11 (permalink) Old 02-23-2013, 02:33 PM
Triplej's Avatar
Yep, called the service manual Not sure if anyone has posted the specs on the forum.
The derby cover torque specs are 84-108 in lbs.
Triplej is offline
post #3 of 11 (permalink) Old 02-23-2013, 02:49 PM Thread Starter
StriderJim's Avatar
Well, that was a pretty fast reply. Unfortunately, not so clever.
I have a service manual, thanks. Now, why don't you cleverly tell me where the specs for the fasteners are........not the torque specs, but the fastener specs.
After all, I was looking to _replace_ a bolt, not tighten it.
post #4 of 11 (permalink) Old 02-23-2013, 02:49 PM
Triplej's Avatar
Found a good link online that gives general guide lines for torque specs for motorcycle. Maybe it will come in handy.
http://raskcycle.com/techtip/webdoc14.html
Triplej is offline
post #5 of 11 (permalink) Old 02-23-2013, 02:53 PM
I use SS allen head bolts which is available at most local hardware stores. Take a old bolt out of your derby cover and take it with you to the hardware store, you can get the allen head bolts in chrome at most ACE hardware stores as well.
post #6 of 11 (permalink) Old 02-23-2013, 02:57 PM
Triplej's Avatar
My bad, misunderstood ya. 1/4-20 x 5/8" is the spec.
Ronnies online will usually show the spec for bolts.
http://www.shopronniesharleydavidson...Y|~HOUSING\KGM
Triplej is offline
post #7 of 11 (permalink) Old 02-23-2013, 03:16 PM Thread Starter
StriderJim's Avatar
Ah! Thanks a lot. Good resource.
post #8 of 11 (permalink) Old 02-23-2013, 04:21 PM Thread Starter
StriderJim's Avatar
Thanks. I'll do that!
post #9 of 11 (permalink) Old 02-23-2013, 05:57 PM
skratch's Avatar
do you have a parts manual? the specs for most (not all) of the hardware can be found in the back of the manual.
example: derby cover bolt, part number 1062. 1/4-20 x 5/8 torx head, grade 8
skratch is offline
post #10 of 11 (permalink) Old 02-23-2013, 06:40 PM
I switched mine out with chrome short headed Allen head . I got them from the HD dealer.
Torque specs for timer cover? Luis FLTRX-13 *General Road Glide Discussions/Pictures 6 09-10-2014 11:25 PM
New Derby/Fuel Door Cover/Timing Cover - D&L Derby Cappers REDRUM *General Road Glide Discussions/Pictures 4 06-09-2014 06:52 PM
Derby Cover / Air Cleaner Cover Jetman Parts for Sale 9 09-08-2013 04:57 PM
Solo seat, BN bag liners, derby cover, primary cover SIC_26 Classifieds Archive (3 months old+) 15 12-27-2012 06:06 PM
Derby Cover specs triple buzz Aftermarket Accessories 6 08-21-2010 10:13 AM
