Think I have a ground short. - Road Glide Forums
  • 1 Post By ChromeSpark
post #1 of 7 (permalink) Old 01-07-2017, 06:59 AM Thread Starter
Rattletrap's Avatar
What is the easiest way to track down a ground short? I know this will be expensive to have mechanic do it and if my bike sits for more than a week the battery is dead. And yes ,already bought new battery so doubt it is that.
Any help would be greatly appreciated.
Rattletrap is offline
post #2 of 7 (permalink) Old 01-07-2017, 07:31 AM
Mike U's Avatar
Rattletrap, an easy way to check for an open circuit, (short to ground) is with a Test Light.
Remove the power feed (fuse, control module) from the suspected circuit.
Disconnect the load and connect one lead of the Test Light to battery positive voltage.
Connect the other lead of the Test Light to one end of the circuit to be tested.
If the Test Light illuminates, there is a short to ground in that circuit.
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 7 (permalink) Old 01-07-2017, 03:18 PM
ChromeSpark's Avatar
So you think you have a parasitic power draw. In cars we've found them by hooking up a micro amp meter (on the battery), then start pulling fuses until you find one that drops the load by a large amount. That will tell you it's on that circuit. If you have pulled all fuses and still have the large draw, start looking for aftermarket hookups (usually what we'd find, ie. amp hardwired to power and draining battery, or similar). In fact normally it was something that was added, every once in a while we'd find a control module that wasn't going to sleep, like it should. Good luck!
MightyWhitey likes this.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #4 of 7 (permalink) Old 01-08-2017, 06:02 AM Thread Starter
Rattletrap's Avatar
Thanks for the info. I will try this once it is warm enough to work on my bike. Unfortunately don't have a garage and the shed is just to cold to start a new project.
i did install hogtunes amp and speakers last year but not sure how to hook it up other than the way it shows in instructions which is straight to the battery. any suggestions on how to do that to see if that solves the issue?
post #5 of 7 (permalink) Old 01-08-2017, 07:42 AM
Ohiobellboy's Avatar
You can pull the fuse for the amp and see if that solves the problem. One question about the wiring on that amp. IIRC, there's two power leads, one to the battery and another to a switched power source to turn on the amp. That "remote on" wire isn't going to constant 12v power is it?
A.K.A OBB
Ohiobellboy is offline
post #6 of 7 (permalink) Old 01-08-2017, 07:46 AM Thread Starter
Rattletrap's Avatar
[QUOTE=Ohiobellboy;3760986]You can pull the fuse for the amp and see if that solves the problem. One question about the wiring on that amp. IIRC, there's two power leads, one to the battery and another to a switched power source to turn on the amp. That "remote on" wire isn't going to constant 12v power is it?[/QUO
One goes to positive battery terminal one goes to the back of 12v power source(cigarette lighter).
post #7 of 7 (permalink) Old 01-08-2017, 04:57 PM
You should be good on that then unless the short is in that CL circuit.
A.K.A OBB
I think I have another convert Bleachey General Off-Topic Discussions 3 08-08-2016 11:24 AM
911- I think its a ground problem... Braveheart1222 Audio 7 10-24-2014 09:36 PM
So you think you have a man cave ?? JacktheBagger Videos 8 11-17-2012 05:35 PM
I think I may have found.... outcast1 *General Road Glide Discussions/Pictures 6 02-13-2012 04:34 PM
I'm short are you short? WhoaD00DHD General Off-Topic Discussions 30 10-17-2011 09:28 PM
