proper clutch engagement - Road Glide Forums
post #1 of 41 (permalink) Old 02-27-2013, 10:02 PM Thread Starter
Onthehunt49's Avatar
i just got my 08 road glide back from being serviced...
clutch lets out almost at the end.(1/2 in or so)..dont remember it like this. used to start engageing about half way..
is this correct or was it wrong before?
or is clutch about gone ?
Onthehunt49 is offline
post #2 of 41 (permalink) Old 02-28-2013, 12:11 AM
Gonekat's Avatar
isnt it just a preference, i have mine adjusted so it begins to engage about a 1/4 in off grip.
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #3 of 41 (permalink) Old 02-28-2013, 07:23 AM
Sounds like the clutch is not adjusted right. Once the clutch is adjusted, then the cable is adjusted so that there is 1/16 to 1/8 inch play in the lever. I use a dime to check mine. It seems like with it having to be released that far to engage, that the clutch might not be fully engaging and may start to slip under load.
Captain13 is offline
post #4 of 41 (permalink) Old 02-28-2013, 07:31 AM
Wild Bill Coady's Avatar
My clutch slips under load, that is when I really jump on the throttle. I've been thinking I have to find time for the dealer. Is it possible it's just a lever adjustment??
RUBBER SIDE DOWN . . . the other way just hurts!
2011 Road Glide Ultra
2003 Electra Glide Classic (RIP 9/3/11)
1987 XLH 1100 30th Anniversary
Wild Bill Coady is offline
post #5 of 41 (permalink) Old 02-28-2013, 07:58 AM
Triplej's Avatar
No need to have the dealer do it, it a pretty easy adjustment if your inclined to do it yourself. Here is a good video showing the procedure. Just make sure the bike is cold when you do it.
https://www.youtube.com/watch?v=Zl92wwLiNwE
Triplej is offline
post #6 of 41 (permalink) Old 02-28-2013, 08:16 AM
Triplej . . . THANKS for sharing and making this the great site that it is.
You guys know everything!
post #7 of 41 (permalink) Old 02-28-2013, 11:18 AM Thread Starter
is that the video i watched that said need to change gasket each time?
is that correct ?
so should have gasket on hand before?
thought about doing it....but since dealer did it...thinking if having them re adjust it if can find time to take it back
post #8 of 41 (permalink) Old 02-28-2013, 12:27 PM
Its suggested to change gaskets, you don't have to and I don't as long as the gasket looks good.
post #9 of 41 (permalink) Old 02-28-2013, 01:20 PM
GRTSHRK's Avatar
In addition to adjusting the clutch some of you may benefit from the upgraded SE clutch spring. Cost is only ~$40 and really firms up the engagement. Don't have the part number handy but found it in the Screaming Eagle catalog. Has been discussed here in the forums too if you want to do some research.
2009 FLTR *Mirage Orange* / SE Heavy Breather / Fuel*Moto Jackpot 4" Dyno Tuned SLASH UP / PC-V / J&M 7.25 Speakers & Hidden Antennae
GRTSHRK is offline
post #10 of 41 (permalink) Old 02-28-2013, 01:20 PM
Triplej's Avatar
I've been known to reuse the primary gasket more than once.
Triplej is offline
2011 RGU Clutch Engagement RGJim Engine Related 9 10-16-2017 09:45 PM
Cluth engagement system: Ater the recall fix Blackbag1 *General Road Glide Discussions/Pictures 18 10-26-2015 12:55 AM
Proper jacking technique? Govdog76 *General Road Glide Discussions/Pictures 19 08-24-2012 08:17 AM
Proper pressures for 2005 Road Glide Rokko100 Suspensions 6 05-25-2012 10:19 AM
