clutch problem - Road Glide Forums
post #1 of 2 (permalink) Old 03-13-2013, 08:33 PM Thread Starter
clutch problem
on my 01 fatboy i adjusted the clutch according to manual with 1 full turn at clutch and 1/8 space at the cable and as soon as i start to release it it engages just as it should with no problem. i got a new 2012 RGU and at a stop on a hill it would chug and bog as i let the clutch out. i thought had a fuel problem so i took it to a dealer and they said it was the clutch and they adjusted it. it was a little better but still chugs and bogs down from a stop on a hill. i inspected their work and there was no play at all in cable and adjusted cable to specs. i need this clutch to engage firmly as soon as i start to let it out.am i missing something ? i did it 1 turn at clutch and 1/8 at cable. i don't know what your plan is to fix it...but i like it already.
thank for any advice
fat boy ultra is offline
post #2 of 2 (permalink) Old 04-01-2013, 06:48 AM
I do mine 1/2 turn on the adjustment. That's by the manual and it works good. Finding neutral is easy and the release is perfect. Just did it last week.
Look at the clutch when you make the adjustment. I could barely feel the resistance when I turned it in so I looked for the clutch to separate. As soon as it moves to release, that is my starting point to back off 1/2 turn.
Captain13 is offline
Clutch Problem after ape install using stock cables Toxicdrop Troubleshooting for Road Glides 5 04-07-2014 10:09 PM
clutch release problem glidelover69 Tech Area 2 06-30-2013 06:53 PM
AIM centrifugal clutch kit problem?? GoodmanHD Engine Related 17 04-14-2013 03:01 PM
Clutch cable problem caboverbob Troubleshooting for Road Glides 13 03-24-2013 09:28 PM
Clutch cable problem after installing new bars WIKD1 Controls & Handlebars 16 12-11-2012 04:37 PM
