Cuts out at Higher RPM's - Road Glide Forums
post #1 of 11 (permalink) Old 03-21-2017, 11:29 AM Thread Starter
2010 RG with A Dyna Jet Having several issues. It started with one cylinder not firing. Shut off engine and restated fine. Next when I get above 4500rpm its just like I hit the kill switch on the bars but let off throttle and it comes back to life. This is intermittent does not do it all the time. So far have changed voltage regulator and battery. Also get O2 sensor trouble codes that can clear but come back as soon as the engine is restarted. Any ideas? This has been in the shop now for the 3rd time. And of course wont happen for the mechanic while on dyno or test ride. The only difference I am 300Lbs and he is 175Lbs not sure if that would make any diffference.
goplay is offline
post #2 of 11 (permalink) Old 03-21-2017, 11:37 AM
sfcusaret2004's Avatar
RPM limiter set too low?
sfcusaret2004 is offline
post #3 of 11 (permalink) Old 03-21-2017, 11:48 AM Thread Starter
Only intermittent. Rev limiter set to 5600.
goplay is offline
post #4 of 11 (permalink) Old 03-21-2017, 01:13 PM
BH#103's Avatar
What kind of testing did the 3 shops perform, any recent service work or related history and what tuner do you have?
BH#103 is offline
post #5 of 11 (permalink) Old 03-21-2017, 01:16 PM
BH#103's Avatar
My bad, what kind of testing did the shop do each time?
BH#103 is offline
post #6 of 11 (permalink) Old 03-21-2017, 01:51 PM
Cylinder heat sensor? Located horn side top of front cylinder. This happen to me and nobody could figure it out.
dozer23 is offline
post #7 of 11 (permalink) Old 03-21-2017, 01:58 PM
PGR
PGR's Avatar
Check the wire going to the map sensor on the induction module. If it's bad, you can touch it. with a stick, with the bike at idle, and the engine will shut down.
Ron..........................
PGR is offline
post #8 of 11 (permalink) Old 03-21-2017, 03:05 PM Thread Starter
They checked ECM and some connections as well as change fuel filter.
goplay is offline
post #9 of 11 (permalink) Old 03-21-2017, 03:11 PM Thread Starter
Dozer23 was your problem intermittent?
goplay is offline
post #10 of 11 (permalink) Old 03-21-2017, 03:28 PM
Yes! It did seem to do it more wile hot or under a load.
Two different dealer were unable to figure it out.
Call who ever looked at the bike last and ask the ? Seems to be over looked often.
Good luck.the part was 40.00 I believe?
dozer23 is offline
Radio volume cuts out when bike is started denharrigan Audio 0 03-25-2017 03:28 PM
Motor cuts out mpowered Engine Related 14 05-26-2014 08:40 AM
Harley's new direction - Higher quality or just Higher Profits? Uncle Fuzzy *General Road Glide Discussions/Pictures 25 04-20-2012 06:29 AM
Radio cuts out on engine start? dbbarton00 Troubleshooting for Road Glides 4 02-18-2012 08:02 PM
cuts out after warmed up... chuckp *General Road Glide Discussions/Pictures 1 03-05-2011 08:42 PM
