Clutch Question. - Road Glide Forums
 3Likes
  • 3 Post By smitty901
post #1 of 4 (permalink) Old 04-27-2017, 10:50 PM Thread Starter
Cobal59's Avatar
Clutch Question.
My clutch action travel play takes much to long engage when releasing the lever. The small range between engage and fully engage makes it to complex to feather, especially with a passenger. The Cable adjustment is correct, and I wondering if changing to a heavy duty clutch spring will improve it or do I need to readjust the clutch at the basket.
Cobal59 is offline
post #2 of 4 (permalink) Old 04-28-2017, 12:08 AM
TheSpartan40's Avatar
I have a hydraulic clutch and put on some adjustable levers. Changed that sweet spot for me. Pretty sure it would work the same on a cable.
2017 FLTRXS
TheSpartan40 is offline
post #3 of 4 (permalink) Old 04-28-2017, 06:24 AM
smitty901's Avatar
When you adjust your clutch do you use 1/2 or 3/4 turn. Try experimenting with that. When I had a cable clutch i generally went with 3/4.
Then adjust the cable to give you your required free play.
Big_gary, 1st Sgt and Road dawg like this.
smitty901 is offline
post #4 of 4 (permalink) Old 04-30-2017, 06:36 PM Thread Starter
Cobal59's Avatar
Thanks It worked.
Thanks Smitty, it worked as you suggested.
Cobal59 is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Clutch Wiz vs Burley easy clutch Trak350 *General Road Glide Discussions/Pictures 14 03-11-2014 09:21 AM
hydrolic clutch question wparoadglide *General Road Glide Discussions/Pictures 6 11-14-2012 11:57 AM
Clutch Question, For Thoes in The Know Nevadasun *General Road Glide Discussions/Pictures 8 08-14-2012 04:41 AM
Clutch Question boneman171 *General Road Glide Discussions/Pictures 1 12-26-2011 10:42 PM
