Need Help No Clutch - Road Glide Forums
 3Likes
  • 3 Post By JacktheBagger
post #1 of 6 (permalink) Old 05-14-2017, 01:41 AM Thread Starter
SOMERG's Avatar
Need Help No Clutch
Well my shift seal went bad on a 2012 RG and of course the whole primary case had to be removed, so I got all the parts started the job this morning. Everything went back fine and now I have no clutch, hard as hell and doesn't engage the clutch pack, everything went back the right way and I adjusted the clutch pin by the book and I have tighten the adjustment all the way and lever has a large gap add feels like a brick.
Well I fix the leak but now have another problem and since' I knew to this bike my knowledge is limited, my son by mistake did engage the clutch lever without the basket on and I"m wondering did that do something on the transmission side. Thanks in advance for any help.
SOMERG is offline
post #2 of 6 (permalink) Old 05-14-2017, 05:57 AM
JacktheBagger's Avatar
sounds like the ramps came off the ball bearings on the trans side . There are two ramps , inner and outer and there are ball bearings between them , one of the ramps has the clutch cable attached .. But alas , how did the clutch get adjusted correctly ?
You will have to remove the exhaust and drain the transmission to get in there ..
Question One : Do you have a service manual ? They explain everything very well .. Should be the first accessory you buy ..
JayKS, Road dawg and Swomack like this.
2011 Ultra
JacktheBagger is offline
post #3 of 6 (permalink) Old 05-14-2017, 08:03 AM Thread Starter
SOMERG's Avatar
Thanks I'll take apart the tranny side, yeah will need a service manual for sure.
SOMERG is offline
post #4 of 6 (permalink) Old 05-14-2017, 10:34 AM
Road dawg's Avatar
Best investment you can do, first thing i bought for my glide the day i picked her up.
Road dawg is offline
post #5 of 6 (permalink) Old 05-14-2017, 04:45 PM Thread Starter
SOMERG's Avatar
Thanks for your help I fixed it, Like you said.
SOMERG is offline
post #6 of 6 (permalink) Old 05-15-2017, 07:53 AM
Glad to help , bill on the way ............
2011 Ultra
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Need help with adjusting clutch maurij1 Troubleshooting for Road Glides 14 06-08-2015 11:22 AM
need help no marker lights BklynRGU Lighting 12 05-06-2014 08:01 PM
Need help- clutch hub nut THEMASTERDESTROYER Engine Related 5 03-06-2013 11:15 AM
Need help: No sound from Factory Stereo when Running DED HD Audio 8 06-30-2011 08:48 AM
