low speed cut out - Road Glide Forums
  • 1 Post By ironmark
post #1 of 7 (permalink) Old 06-10-2017, 05:04 AM Thread Starter
mydime's Avatar
low speed cut out
i have a 2015 rg special with 14996 miles
it has a heavy breather and not cat .
why does motor cut out at low rpm?
it does have a modest ecm tune to run richer.
it just stared to doing this and just not sure why.
thank you
mydime is offline
post #2 of 7 (permalink) Old 06-10-2017, 07:29 AM
thank you
Explain your tune, modesty.
post #3 of 7 (permalink) Old 06-10-2017, 10:15 AM Thread Starter
mydime's Avatar
i took it to HD dealership to have the ecm flashed supposedly it runs alittle richer than before .
and for 6 months i had no issues,
now at low rpm,s it back fires or pops through heavy breather and it seems to stumble and pop at 75 mph at around 3k rpms ,,like it will surge forward then feel like it is being held back.weird thing it wasnt like this before or after that ecm flash months back
mydime is offline
post #4 of 7 (permalink) Old 06-10-2017, 10:34 AM
Thermodyne's Avatar
Check it for codes, it might just tell you what it's issue is.
Other than that, has all the maintenance been done, new plugs and such. Plug wires checked.
It could be a lot of stuff. Way to much for poking and hoping. Bad crank sensor, bad coil, fuel pump issues, vacuum leak.
Thermodyne is offline
post #5 of 7 (permalink) Old 06-10-2017, 10:38 AM Thread Starter
mydime's Avatar
hmm well it has new plugs and the 10 mm SE wires ,they are new.
maintenance is done,
thought it might have something to do with the tca behind the air cleaner
mydime is offline
post #6 of 7 (permalink) Old 06-11-2017, 09:22 AM
The first thing I would check is the vacuum stem on the top of the throttle body, if the cap is broken or missing then you could have running issues. Is the bike still under warranty ? If so this may be a good time to use it.
mydime likes this.
post #7 of 7 (permalink) Old 06-12-2017, 12:56 PM Thread Starter
mydime's Avatar
i think i might have found my problem
when i took my air breather off i noticed my gasket was not sealed completely at the bottom of the throttle body to the air cleaner.i have yet to test it but i think maybe that was the problem
mydime is offline
5 speed or 6 speed?? Pooh63 *General Road Glide Discussions/Pictures 8 06-22-2017 01:20 PM
Contrast Cut VS Platinum Cut RhinoHD Wheels and Tires 23 02-03-2014 10:27 PM
to cut or not to cut mroach Controls & Handlebars 6 03-06-2012 07:17 PM
Slight front end shake/wobble at low speed smitty901 Troubleshooting for Road Glides 2 04-28-2011 10:59 PM
Low Speed Wobble and New Bars??? jbrawkus Controls & Handlebars 14 04-13-2010 07:35 PM
