Alarm/ turn signal problem - Road Glide Forums
post #1 of 4 (permalink) Old 04-21-2013, 04:18 PM Thread Starter
HDGypsy's Avatar
While out riding I noticed I had lost my right turn signal, both front and rear. I checked the bulbs and they were ok and then my alarm light(little key) stays on all the time. I was planing on taking it into the shop tommorow but figured I would check to see if anybody has had this problem. Thanks in advance.
12 FLTRU Big Blue Pearl
98 Wide Glide
HDGypsy is offline
post #2 of 4 (permalink) Old 04-21-2013, 06:36 PM
ENG25TRK's Avatar
Have you done any custom work recently?
Had the fairing off lately? You might have a pinched wire at the turn signal mount.
Do you have LED signals? You might need a load equalizer.
Do your 4 way flashers work? Do the signals flash when the bike alarm is armed?
Did you run diagnostic check? Search the forum for instructions on how.
ENG25TRK is offline
post #3 of 4 (permalink) Old 04-21-2013, 08:51 PM Thread Starter
HDGypsy's Avatar
Thanks for your reply, I found a pinched wire on the right front signal mount .
98 Wide Glide
HDGypsy is offline
post #4 of 4 (permalink) Old 04-21-2013, 09:37 PM
ENG25TRK's Avatar
Glad to help. Same thing happened to me a couple years ago. Drove me nuts!
ENG25TRK is offline
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 03:26 AM
turn signal/alarm system?? opr1945 Troubleshooting for Road Glides 12 07-21-2013 12:49 PM
front turn signal plug problem? gmorris Lighting 4 04-14-2013 03:58 PM
Turn signal problem Doug06rg Troubleshooting for Road Glides 4 01-08-2012 12:42 PM
problem with right rear turn signal/running light Big Moke Troubleshooting for Road Glides 0 04-27-2011 09:34 AM
