Bike wouldn't start - Road Glide Forums
post #1 of 28 (permalink) Old 04-22-2013, 01:40 PM Thread Starter
TRUBlue's Avatar
Bike wouldn't start
I had an issue yesterday that stranded me. Had to do the tow truck thang, ouch, I'll leave that for post elsewhere. Had almost exactly the same issue that 13HDGLIDE did and posted last week: https://www.roadglide.org/showthread....ighlight=idiot
Except, mine didn't start then stall, it just didn't start. Was running perfectly until I stopped. It would turn over but no fuel pump noise-no engine light. Having just read most of the above thread on Friday I immediately checked fuses. All looked good, swapped out the spare for the fuel pump and the ECM, no go. Bike in neutral, switches on and off several times but no cycling of fuel pump heard. New battery in key fob too.
If I don't figure it out tonight, dealer is picking up tomorrow. 2.5 months left on the warranty.
Ideas?
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #2 of 28 (permalink) Old 04-22-2013, 05:09 PM
BrianKampa's Avatar
I had a similar issue, turns out one of the connections under the seat came loose from changing out seat all the time. It loosened the connections. I dunno, shot in the dark. Was a black square connection in front of the ecm. Had a tow teuck on way and i played around with it, then heard fuel pump cycle. Fired right up
BrianKampa is offline
post #3 of 28 (permalink) Old 04-22-2013, 08:55 PM Thread Starter
TRUBlue's Avatar
Blown fuse, evidently I couldn't see it in the low light. Makes me wonder what caused it.
TRUBlue is offline
post #4 of 28 (permalink) Old 04-22-2013, 09:18 PM
What fuse ? ECM ?
Big_gary is online now
post #5 of 28 (permalink) Old 04-22-2013, 09:20 PM Thread Starter
TRUBlue's Avatar
Originally Posted by Big_gary View Post
What fuse ? ECM ?
Exactly, wondering what I did to overload the circuit.
TRUBlue is offline
post #6 of 28 (permalink) Old 04-22-2013, 09:25 PM
TimMCc's Avatar
Trouble shooting 101, check power supply.
Glad it was simple, but now I'm curious as to why it blew. Let us know.
Hold fast!
TimMCc is offline
post #7 of 28 (permalink) Old 04-22-2013, 09:26 PM
You got any amps hooked up ?
post #8 of 28 (permalink) Old 04-22-2013, 09:39 PM Thread Starter
TRUBlue's Avatar
No, stock in that regard. I don't remember if the radio was on. A lot of times I have it on but muted so I don't have to reach to turn it on while riding. I saw a thread a while back about "proper" shutdown. I don't remember what the consensus was but I normally use the switch on the handlebar then the ignition switch.
TRUBlue is offline
post #9 of 28 (permalink) Old 04-22-2013, 09:44 PM
93-331-29psi's Avatar
I shut mine off using both methods and I've never had an issue. Hope you figure out the cause soon. Any codes?
Sent from Motorcycle.com App
93-331-29psi is offline
post #10 of 28 (permalink) Old 04-22-2013, 09:48 PM Thread Starter
TRUBlue's Avatar
No codes, first thing I checked once I was back up and running. Was hoping to find something.
TRUBlue is offline
I wouldn't call it wobble, but.... Would like some inputs Matt990724 *General Road Glide Discussions/Pictures 29 07-19-2012 05:08 PM
And she wouldn't let me wrap one present.... tcon287 *General Road Glide Discussions/Pictures 4 12-25-2011 04:19 PM
Wouldn't catch me dead DemonCity General Off-Topic Discussions 32 09-07-2011 10:20 PM
Wouldn't it be cool... BLKNCr6 ARCHIVES-SWI Gettysburg, PA 1 07-22-2011 09:16 AM
