Trans Gasket? - Road Glide Forums
post #1 of 6 (permalink) Old 09-27-2017, 03:55 PM Thread Starter
Trans Gasket?
Just got in from a destin trip, round 1000 miles. Noticed this leak under the bike. It's a 2012 RG with 15k miles. Was serviced not long ago. Also noticed a bit of vibration when nearing the Rev limiter thru the gears. Would this be a gasket causing the leak? What about the vibrations?
NAFD-315 is offline
post #2 of 6 (permalink) Old 09-27-2017, 04:03 PM Thread Starter
Pic
File Type: jpeg 90F1E582-BEC7-4BB8-8DE2-9BD5B9A71C78_1506546122407.jpeg (1.47 MB, 22 views)
NAFD-315 is offline
post #3 of 6 (permalink) Old 09-27-2017, 05:17 PM
I had a 2009 that developed a similar leak. Check that the two screws on the bottom of the transmission cover are tight. Those screws also attach the exhaust mount and can vibrate loose, and they are difficult to get to with the header attached. I removed the heat shield to make access easier. I believe they are 5/16 or maybe 1/4. Anyway, the hex end of a multi-bit screwdriver bit fit the hex screws perfectly. I then used a boxed end ratcheting wrench slipped onto the bit to tighten the screws if that makes any sense. Some people also cut down a hex wrench so it will fit into the small space. It’s kind of hard to explain.
PeteF is offline
post #4 of 6 (permalink) Old 09-27-2017, 05:44 PM
bucketlisthd's Avatar
My 09 had that problem. My Indy told me to take the 2 bolts all the way out, clean them, and put red loctite on. He said that the leak would be a reoccurring issue otherwise.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #5 of 6 (permalink) Old 09-27-2017, 06:03 PM Thread Starter
Seems it may be coming from here?
File Type: jpeg C6EAE3D9-2425-42B6-9C83-0C06449E5C23_1506553322221.jpeg (1,011.5 KB, 19 views)
NAFD-315 is offline
post #6 of 6 (permalink) Old 09-27-2017, 06:51 PM
Check them all, but make sure the two screws at the bottom are tight. They tend to loosen over time.
PeteF is offline
Andrews 31T trans sprocket pulley North Star Sold 1 04-23-2012 09:23 PM
Trans oil TAuston *General Road Glide Discussions/Pictures 42 10-07-2011 08:37 PM
Baker 30 or 31 tooth trans pulley????? gabbyduffy Engine Related 36 07-23-2011 01:12 AM
Trans noise THEMASTERDESTROYER Troubleshooting for Road Glides 20 07-08-2011 11:21 AM
Trans Lube Change Luscruz Troubleshooting for Road Glides 10 09-18-2010 07:08 PM
