rear cylinder missing - Road Glide Forums
post #1 of 14 (permalink) Old 09-28-2017, 02:04 PM Thread Starter
littlejoe's Avatar
I have a 2013 RG that just started the rear cylinder missing intermittently. its started yesterday and i thought it had to do with riding in rain recently. Came out of it after a couple miles and is now do it doing it again. The fuel tank was low so I thought maybe I had gotten some bad gas filling up again did not seem to help. When it idles, it revs high. Any suggestions? Thank you
littlejoe is offline
post #2 of 14 (permalink) Old 09-28-2017, 02:37 PM
wevsspot's Avatar
I'd start at the plugs and work your way back. Plugs, plug wire, ignition coil, charging system and battery / battery connections. If all that looks OK you'll need to move onto the fuel system. If it's neither spark or fuel guess you might do a compression / leak down test on the rear cylinder. My cousin rides a 2011 HD and he was having a very similar issue. Seemed like the rear cylinder was miss-firing. We changed plugs, replaced the rear plug wire, checked fire from the coil and then went through the fuel system. We didn't check the battery because it was less than 2 months old. Problem persisted. Travis called me a couple of days later and said his bike was dead in the parking lot of the gym and that he needed a jump or a tow.
I got on the road and about 20 minutes later he called and said that he had a loose terminal on his battery. He tightened that up and hasn't had an issue since.
Maybe you'll get luckly...................
The last thing I can think of is that maybe the rear cylinder O2 sensor is acting up.
wevsspot is offline
post #3 of 14 (permalink) Old 09-28-2017, 03:48 PM
bucketlisthd's Avatar
You can reset the idle with the bike off. Cycle the ignition on-off deliberately 4-5 times. ( Can't remember which) Restart and idle should be correct.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 14 (permalink) Old 10-02-2017, 11:29 AM Thread Starter
littlejoe's Avatar
followup
I did not have much time to work on it this weekend but I notice when it starts it runs fine for a while, like ten to fifteen minutes. Then is starts missing on rear cylinder. The bike has about 19000 miles so I wonder if it might be fuel filter or full pump. I will try to work on it this week. Thanks for the advise
post #5 of 14 (permalink) Old 10-02-2017, 11:42 AM
skratch's Avatar
you aren't referring to the eitms by chance are you? how about more info as to what the conditions are when it is doing it?
skratch is offline
post #6 of 14 (permalink) Old 10-02-2017, 11:55 AM
mastergunnera8's Avatar
Something similar was going on with a friends bike last weekend, he took off the air cleaner , looked at the wiring under the manifold and found a couple wires that had insulation worn though and were grounding out..fixed them and running great so far...
mastergunnera8 is offline
post #7 of 14 (permalink) Old 10-03-2017, 08:35 AM Thread Starter
littlejoe's Avatar
Thanks
I have been riding in rain an awful lot lately so wiring is a concern. I just haven't got a good chance to work on it yet. It does start well and run strong on both cylinders for a while. Then it starts shutting down on one cylinder. The rear cylinder will kick in intermittently but wrote run right till i let it set a while.
post #8 of 14 (permalink) Old 10-03-2017, 09:40 AM
Dragon Dude's Avatar
I don't know what kind of coils we have, but i do know some coils can over heat and stop working or not put out enough spark to keep the cylinder firing. Let it cool down and it will work till it over heats again. Not saying this is your problem, but worth it to maybe check it out.
Dragon Dude is offline
post #9 of 14 (permalink) Old 10-03-2017, 10:19 AM
Same deal with my friends...he resets the computer, turn on and off ignition a few times..are you getting any codes?
post #10 of 14 (permalink) Old 10-10-2017, 08:28 AM Thread Starter
littlejoe's Avatar
I was not getting codes but I tried to start it this weekend and it wouldnt start. So now I am getting p1002 code which I believe is a ECM type code. I will look it up. Maybe some kind of short because of all the riding in thunderstorms. You all have been very nice helping. Thanks
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 02:46 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 12:07 PM
WTB stock rear brake master cylinder Swagzilla Wanted! (Buy or Trade) 2 06-28-2012 05:10 PM
Rear Cylinder misfire blkbusa Troubleshooting for Road Glides 10 02-14-2012 02:56 AM
Rear cylinder kill opt. Big_gary *General Road Glide Discussions/Pictures 20 03-05-2011 08:02 PM
