swapping rims and sprocket. ..help - Road Glide Forums
post #1 of 19 (permalink) Old 05-06-2013, 12:03 AM Thread Starter
Easyryder01's Avatar
I purchased a set of OEM wheels from a fellow memeber and the rear wheel didn't come with a sprocket. ....I thought nothing if it since I already had one so I was curious do I need to rebalance my rim after I put my sprocket on the new wheel. Just to let ya know the wheel being swapped is a magazine wheel and the same size as my OEM wheel on my RGU. Everything the same other than design. Any help would be greatly appreciated. Thank you very much.
2017 RGS Velocity Red
Easyryder01 is offline
post #2 of 19 (permalink) Old 05-06-2013, 03:41 AM
JacktheBagger's Avatar
I dunno about rebalancing but don't reuse the bolts
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 19 (permalink) Old 05-06-2013, 06:26 AM
93-331-29psi's Avatar
It's good practice to balance all moving parts on either wheel (sproket, rotors etc), but may not be necessary. I've swapped rear wheels before without including the sprocket in the balance before and have had no issues. It's luck of the draw, and I personally would try running it as is without a balance.
93-331-29psi is offline
post #4 of 19 (permalink) Old 05-06-2013, 06:40 AM Thread Starter
Thank you for the assistance on this I appreciate it. Just curious about the bolts though any idea why something like that you may not reuse them ? Is it a torque thing ? Or ?
post #5 of 19 (permalink) Old 05-06-2013, 07:20 AM
Jetman's Avatar
I'm not sure of why it is recomended to replace all boilts , but I'd think as much stress as they take, for a few bucks, I'd do it. As far as balancing goes, I stopped useing stick on weights years ago. Dyna beads work great! Installation DURING Tire install is the easiest, but you CAN install THRU the valve stem after the fact (just need some patience). Need a 2OZ bag per wheel for our size wheels. Good Luck!
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #6 of 19 (permalink) Old 05-06-2013, 08:37 AM
faststan's Avatar
Those bolts are made to stretch when installed. They will only stretch so far before breaking. Good idea to follow those recommendations.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 19 (permalink) Old 05-06-2013, 08:41 AM
They recommend replacing bolts because the threads stretch and won't grab/torque properly and run the risk of backing out. I always replace them. Small price for peace of mind.
Sent from Motorcycle.com App
post #8 of 19 (permalink) Old 05-06-2013, 10:36 AM Thread Starter
I forgot to ask but how do you remove the sprocket off the wheel ? Where do you get those balance beads ?
post #9 of 19 (permalink) Old 05-06-2013, 11:52 AM
Did the wheel come with the tire on it?
reds4 is offline
post #10 of 19 (permalink) Old 05-06-2013, 12:35 PM Thread Starter
Yes the tire came on the wheel. Based on the date of the tire it seems like its the original tire. I'm looking to get this rim and tire mounted in my bike ride it a little bit and then put in a claim for the tire with a nail in it with my tire and wheel coverage on ESP. I just would like to get my sprocket off and my bike off the lift, just don't know how to.
Overdriving Primary Compensator sprocket or swapping out to 6 speed gearset silverglide Engine Related 6 05-22-2016 09:29 AM
Sprocket / pulley change on 2013 and 2015 Deadstroke Engine Related 6 10-05-2015 11:13 AM
Two week old bike and already swapping out the exhaust. ndronet Intake and Exhaust 8 07-08-2013 09:15 PM
Pros and cons to swapping out cartridge left fork... Nick-O Suspensions 6 01-05-2013 08:08 PM
FS: 25/36 Sprocket and clutch basket spider445 Classifieds Archive (3 months old+) 0 08-20-2012 01:57 PM
