Chirping sound when decelerating - Road Glide Forums
 3Likes
post #1 of 15 (permalink) Old 12-22-2017, 07:07 AM Thread Starter
bless0's Avatar
I get a weird chirping sound when I decelerate especially when the engine is cold. It only happens when the bike is under load in gear and especially when I first start riding. I am trying to figure out if its coming from the engine or from the drive train. If I rev the engine in neutral and let off I don't hear the chirping sound. When I am accelerating and let up to press the clutch and shift I hear the chirping sound as load comes off the engine and drive train. Eventually as the bike get hot the sound is a lot less. Anyone experience this weird sound. Chirping is the best way I can describe it.
I have a 2015 RGS SE intake Rush power duals and Rinehart 4" slipons.
bless0 is offline
post #2 of 15 (permalink) Old 12-22-2017, 07:17 AM
norm9278's Avatar
Check for loose exhaust flanges. A head gasket can also cause a chirping sound.
norm9278 is offline
post #3 of 15 (permalink) Old 12-22-2017, 07:23 AM Thread Starter
bless0's Avatar
I will def check those again. Wouldn't I get the sound regardless if I was under load or not. If I am in neutral and rev the engine I don't get the sound. It is most pronounced when I let go of the accelerator when I am in gear.
bless0 is offline
post #4 of 15 (permalink) Old 12-22-2017, 08:09 AM
I had a similar chirping sound. They ended up replacing the rocker arms and shafts because the shaft was rubbing against the head. 100 miles without the chirp so far.
US ARMY 1975-1985 IBA 69057 2017 RGS; 107; Stage I; Low Z chizeled handlebars; chopped engine guard; SE Mufflers; LED Cluster lights; Clearview Windshield; heated grips; lighted switches; Custom seat from Mean City Cycles.
2016CTRoadGlide is offline
post #5 of 15 (permalink) Old 12-22-2017, 08:19 AM
lil chief's Avatar
First thing to check is the belt. The chirp on decel is a classic symptom of it being too loose, then the noise goes away as the belt gets warm and tighter. Do this before you tear into the motor.
Lil Chief
flhman, psrumors and hawwk like this.
lil chief is offline
post #6 of 15 (permalink) Old 12-22-2017, 09:02 AM Thread Starter
bless0's Avatar
Thanks for the advice. I will def check the quick and easy first.
bless0 is offline
post #7 of 15 (permalink) Old 12-22-2017, 10:05 AM
Morningwood's Avatar
I am experiencing the "exact" same thing as you are describing. I was thinking that it is coming from the front exhaust port. When I installed the new header the front flange felt "off" I tested it for leaks, cant identify any even now. To solve the problem I ordered a new exhaust system and will install this spring. (I realize I don't need a new system, but it was a good excuse). 2016 RGS, fuel moto header, I always wanted the V&H super radius, on sale at JP cycles for $509-$569. Hopefully I can get these aligned properly and it solves the problem, if it is the problem.
Morningwood is offline
post #8 of 15 (permalink) Old 12-22-2017, 10:12 AM
I checked the belt and it is set to the manual, the sound seems to be coming from the front right area of the engine, but goes away after 10 minutes or so, up to temp I guess. In my illogical mind I figure the heat expands the metal and seals the gasket, but as you said it doesn't do it in neutral. I will check more into the rockers and belt just to be sure.
post #9 of 15 (permalink) Old 12-22-2017, 10:35 AM
norm9278's Avatar
Does it chirp when sitting still or only when moving? If it only does it when moving, check the belt alignment to the sprockets. Alignment, not tension. If the rear wheel is slightly cocked to the side it can chirp, especially when it's cold. The belt must run in the center of the sprocket, not rubbing the shoulder on either side.
norm9278 is offline
post #10 of 15 (permalink) Old 12-23-2017, 08:26 PM
KansasFLTRU's Avatar
Itís guys like YOU who make so many guys like US feel normal. Thank you, Morningwood! Thank [email protected]
KansasFLTRU is offline
Vibration while decelerating onderk Troubleshooting for Road Glides 4 05-15-2018 12:50 PM
Bike dies while decelerating 2012 FLTRX oc357 Troubleshooting for Road Glides 3 03-11-2018 02:53 PM
chirping noise on gear change gja Troubleshooting for Road Glides 10 04-19-2014 08:14 AM
Chirping sound Kevian Troubleshooting for Road Glides 10 08-01-2011 09:27 PM
chirping noise on deceleration cballjr54 Troubleshooting for Road Glides 13 10-21-2010 07:46 PM
