CVO TPMS on a special... - Road Glide Forums
 14Likes
post #1 of 47 (permalink) Old 12-23-2017, 06:28 AM Thread Starter
RFG7680's Avatar
Anyone done this?
I'm upgrading to the Agitators and am wondering if anyone has installed the tpms and had their system flashed to the CVO software and had it work. I don't see why I couldn't. Same 6.5 Boom system. Should just be a software update, no? Unless the rim dictates wether or not the sensor will fit.
RFG7680 is online now
post #2 of 47 (permalink) Old 12-23-2017, 07:31 AM
There is a thread about this on the CVO website, having to do with adding TPMS to a '15 CVO. This option was not introduced until 2016.
From what I remember (as I wanted to do this on my '15 CVO), the wheels ARE part of the issue. Only the '16 wheels will work. Then there was the BCM (body control module) which needs to be changed as well as that has the receiver for the TPMS. I talked with my dealer and they said they thought there were a few additional issues (but they may not have been correct as they never attempted this).
If it was just a BCM change, I would have done it, as I'd like to have added that feature. ON the other hand, some I've spoken to a few people that have the TPMS, and they tell me it's not very accurate and sometimes more annoying than helpful.
Anyway, you might want to check on the CVO site and post there to see if the OP ever moved forward with the upgrade.
zigzag930 is offline
post #3 of 47 (permalink) Old 12-23-2017, 07:41 AM
twowheeladdict's Avatar
Many people don't realize the true value of having TPMS. I hear a lot of comments about checking my air pressure with a quality gauge so I see no need for TPMS.
For me, knowing what the air pressure is without having to use a gauge is just a side benefit of having TMPS.
The main benefit is when you puncture a tire and the system alerts you of the air loss so you can safely pull over to the side of the road before the bike gets squirrelly.
My sport touring bikes came with TPMS, and I did get a puncture on the Concours 1400 that became a non event instead of a pucker moment in the rain while going 55 mph, or worse.
I have a Doran TPMS system that gets hard wired to the bike, but the sensor batteries are not replaceable and you need to change out the valve stems to metal ones.
I am thinking about the FOBO system next that syncs to your smart phone. I have a spare smart phone (basically a tiny tablet) that I can mount to the bars and use as the pressure monitor as well as stream music and a backup GPS / Weather device since I can network it to my phone by turning on the mobile hot spot. Then my phone is not subject to loss or damage.
It really is ridiculous that Harley doesn't have TPMS on all their touring bikes.
Lu, vring, RFG7680 and 2 others like this.
twowheeladdict is online now
post #4 of 47 (permalink) Old 12-23-2017, 09:59 AM Thread Starter
RFG7680's Avatar
They have the ones that Bluetooth to my phone. I was planning on getting them but figured I'd check the collective first.
Awesome info guys. Thanks.
post #5 of 47 (permalink) Old 12-23-2017, 10:05 AM
When it is time for me to get new tires, I am going to order the FOBO set and metal "T" valve stems. Just have it all done at the same time. It is a pain in the ass to check the tire pressure on the rear, and therefore I don't do it as often as I should.
vring, Taz_FL, noneckg and 1 others like this.
macabra11 is online now
post #6 of 47 (permalink) Old 01-16-2019, 10:18 AM
craigffb's Avatar
Sorry for dragging up this old thread, but this is starting to gain some traction on HDForums.
Here is the link if you want to check it out: https://www.hdforums.com/forum/milwa...5871-tpms.html
I hope this ends up working cause I'd like to have it.
craigffb is online now
post #7 of 47 (permalink) Old 01-16-2019, 12:29 PM
jchar27's Avatar
Just my two cents, I don't know how or if I'm lucky, but the TPMS on my '18 CVO is dead on accurate. Every time I manually check it, and I mean every time, it's identical to what the bike is telling me.
ALMOONEY likes this.
2018 CVO Road Glide, Black Earth/Vivid Black
Fuel Moto Road & Track 2 into 1, Fuel Moto custom K & N Air Cleaner, Redshift 468 cam, Power Vision.
2003 Super Glide 100th Anniversary Edition
jchar27 is offline
post #8 of 47 (permalink) Old 01-16-2019, 12:51 PM
craigffb's Avatar
I'd really like to have this on my bike.
post #9 of 47 (permalink) Old 01-16-2019, 02:07 PM
BH#103's Avatar
As far as I recall, you have to have the Digital Technician hooked up to be able to turn on the features and also have the supporting sensors installed in the wheels.
"SLIVER"
BH#103 is offline
post #10 of 47 (permalink) Old 01-16-2019, 02:43 PM
craigffb's Avatar
As far as what I've read and be told by a tech at my local HD shop, the Digital Technician turns on the option is the radio as well as the gauges, but it's done separately. Then when the sensors are mounted in the wheels a hand held unit is used to activate the sensors so the radio knows which is the front and which is the rear.
The parts I don't know is if the wheels on my bike will actually accept the sensors and once the sensors are on the wheels will the radio actually read them. Everything else has been verified.
Malcam TPMS Morningwood Aftermarket Accessories 18 03-17-2018 07:03 PM
FOBO TPMS T-valve Pictures tsmartt Wheels and Tires 19 01-17-2018 06:29 AM
Tpms ia15rgs Do-IT-Yourself 16 06-02-2017 01:57 PM
CVO handlebars on a special? Khodne Controls & Handlebars 2 11-03-2016 06:11 AM
2013 cvo speaker lowers 2016 road glide special griswold Audio 2 05-10-2016 09:26 PM
