Noise - Is it normal? - Road Glide Forums
post #1 of 12 (permalink) Old 05-20-2013, 10:25 AM Thread Starter
Dragonback's Avatar
Let me start by saying that this is my first Harley.
13 RGC -
I dont recall this happening when I got it so Im curios if its just wear or something came loose...
Whenever I shift Gears I hear a slight clank when I pull the Clutch lever in... I hear a clank when I throw into gear (any - and I think this part is normal) but also hear a slight clank when I release the clutch - BTW i hear the clank on pull and release even if I don't switch gears... Also...
If I'm cruising .. and I release the throttle I hear a clank and it i hit the throttle to continue the cruise after real ease.. I hear a clank...
Dealer stated it was normal ,... stated "compensator in Primary" would have a slight lag so when "Gears" engage it will male the noise..
I dont recall hearing till after they did 500 mile tune and went to Synthetic...
BTW.. it all seems to be coming from inside the Primary...
Anyone have any Ideas... Could it be something Got loose?
Appreciate any feedbacks
Black Bike Matters !!!
They say.. Its not What you ride ... but That you ride.. guess they aren't riding a Harley!
Dragonback is offline
post #2 of 12 (permalink) Old 05-20-2013, 10:52 AM
Venomized's Avatar
My 07 does the same thing. It annoys the hell out of me but I think its normal. Ill let someone else confirm this though.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 12 (permalink) Old 05-20-2013, 10:59 AM
rdrnr03's Avatar
Just had mine in fr that same noise but it was all the time. My compensator bolt came loose and f'd up the bearing in there. Thank god for extended warranty. Total bill would have been 1100.
rdrnr03 is offline
post #4 of 12 (permalink) Old 05-20-2013, 11:09 AM
Rowdy's Avatar
I am by no means a wrench, but IMO you could call bullshit on your dealer. It's not normal IMO. Again I am not a wrench, but I would get a second opinion from either another dealer or a reputable independent.
Rowdy
Rowdy is offline
post #5 of 12 (permalink) Old 05-20-2013, 11:22 AM
bombdog's Avatar
I agree with the BS call I have a 13 RGU and have no Clanks cept sometimes when it goes into gear that would be normal but not when you engage the clutch. However I am also no wrench but I did stay at a Holiday Inn Express.
The early bird gets the worm BUT the Second mouse gets the cheese......
bombdog is offline
post #6 of 12 (permalink) Old 05-20-2013, 11:45 AM
I agree with Rowdy and bombdog, I say take it back to the dealer, or have a different dealer check it.
post #7 of 12 (permalink) Old 05-20-2013, 01:54 PM Thread Starter
Dragonback's Avatar
Thanks all for the Input... have appointment for later this week!!
post #8 of 12 (permalink) Old 05-20-2013, 09:49 PM
Warpath 41's Avatar
Let's us know the outcome. Thanks
[SIGPIC[/SIGPIC]2013 Candy Orange RGC-Power Vison Tuner, De-Catted Head Pipe, Jackpot 4" Slip-Ons, Fuel Moto Billet A/C, Wild 1 502 Chubby's, Painted Inner, Color Matched Vented Lowers w/Boom Speakers, 12" Windvest..........
Warpath 41 is offline
post #9 of 12 (permalink) Old 05-21-2013, 02:09 PM
Venomized's Avatar
Yea post up the outcome so we all have the answer!
'07 Pewter Pearl
post #10 of 12 (permalink) Old 05-21-2013, 02:44 PM
RedneckMedic66's Avatar
I would pull your primary cover and check the clutch adjustment. Loosen your clutch cable. Pull the cover. Loosen the jam nut in there using a alan wrench and an open socket. Then tight the alan just until it touches and meets resistance then loosen a 3/4 turn. Tighten the jam nut back up and replace primary and readjust clutch lever. See if this helps. Plenty of vids on the you tube if you don't understand what i just said.
GLIDE OR DIE!!
RedneckMedic66 is offline
Normal Noise or is there a fix KennyD104 Intake and Exhaust 10 08-04-2017 03:21 PM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Is this noise normal? Steelerdude1 *General Road Glide Discussions/Pictures 16 11-24-2015 02:40 AM
HELP... is this engine noise normal ? Still Grumpy *General Road Glide Discussions/Pictures 4 12-05-2012 11:26 AM
A good dose of "Normal" Tytanium *General Road Glide Discussions/Pictures 30 03-09-2011 03:51 PM
