loosing power - Road Glide Forums
 3Likes
post #1 of 20 (permalink) Old 04-20-2018, 09:16 AM Thread Starter
gsbuick65's Avatar
loosing power
My 2011 103 doesn't have the power it should. Most noticeable at about 80. When I get on it it just bogs. Mileage has Dropped about 5 mpg. I've changed plugs and fuel filter. Fuel pump has correct pressure but he didnt check it at 80 cause I have a car tire.
gsbuick65 is offline
post #2 of 20 (permalink) Old 04-20-2018, 01:00 PM
BlazingSaddle's Avatar
Any changes to the bike since it developed the problem? Piggyback or aftermarket tuner on it? Coil? Spark plug wires? Bad ground? Air, fuel or spark. Itís either choking or drowning. If youríre losing gas mileage, sounds like running to rich. ECM? Under load only or only at certain RPMs? Checked to see if youíre throwing any codes? How many miles on the clock? Not one of those things you can immediately put a finger on, but more a process of elimination.
BlazingSaddle is offline
post #3 of 20 (permalink) Old 04-20-2018, 04:45 PM Thread Starter
gsbuick65's Avatar
nope, put tuner on at 3500 it has 57000 now, well thats when i notice it under load, but i can tell in any gear just worse in 6th guess because of gear ratio. it started doing it about 45000.
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
post #4 of 20 (permalink) Old 04-20-2018, 04:50 PM
May be it is the case to run a compression check to verify cylinders performances, it is not invasive and it is a good engine health marker.
RGKen likes this.
Beaver is offline
post #5 of 20 (permalink) Old 04-21-2018, 09:00 AM
The dark side could effect mileage. Car tire has a bigger footprint causing more resistance but it shouldn't effect performance. Just a thought.
Buzzy is offline
post #6 of 20 (permalink) Old 04-21-2018, 09:27 AM
Thermodyne's Avatar
I would run a leakage test, see what kind of shape the top end is in. Use a bore scope to read the piston tops.
Those early 103 ran hot, 11's were really bad. So the rings tend to go away early and the bores are seldom round at tear down.
If it still has a cat on it, it could be stopped up, they don't do well when the rings pass oil. A vacuum gauge will tell the tail on that. If the vacuum falls off with the power, suspect a clogged cat.
Other than that, I would suspect something in the tune, or one of the sensors. Data stored in memory can get buggy. And sensors wear out. You can sit down and test the sensors with a breakout devise, like a twin scan, and with some tuners you can record and read the data to see what was going on when it was acting pissy.
RGKen and eddienelson like this.
Thermodyne is offline
post #7 of 20 (permalink) Old 04-22-2018, 10:27 PM Thread Starter
gsbuick65's Avatar
no cat has true duals. I thought maybe it was the tune so I loaded stock tune and took tuner off.
Oh and it don't do it all the time, and I don't notice it unless I accelerate fast,and the Exhaust sounds different
post #8 of 20 (permalink) Old 04-23-2018, 07:09 AM
Check the throttle body/injector body for a broken butterfly pivot rod.
Buzzy is offline
post #9 of 20 (permalink) Old 04-23-2018, 09:38 AM Thread Starter
gsbuick65's Avatar
Would injectors cause this?
post #10 of 20 (permalink) Old 04-23-2018, 09:39 AM Thread Starter
gsbuick65's Avatar
Wouldn't that do it all the time?
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Iphone and loosing volume rob883 Audio 2 02-05-2014 01:13 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
Power Commander V and Big Sucker Air Cleaner The Infamous Sharknose Equipment-RG 0 09-18-2009 10:07 AM
