Key Lock - Road Glide Forums
 3Likes
  • 1 Post By geo8866
  • 1 Post By NeverEnough
post #1 of 10 (permalink) Old 04-25-2018, 02:24 PM Thread Starter
Question Key Lock
2015 RGS- When i put key in ignition switch & try to lock it by pushing down & turning clockwise , it is hard to turn. Im afraid of breaking the key. I tried WD40- no help. This happens when locking & unlocking. Any help???
nanook is offline
post #2 of 10 (permalink) Old 04-25-2018, 03:07 PM
I had the same problem for a while on my 17. I removed the ignition and made sure it was aligned correctly, put it back in, lubricated it, it’s been fine now.
post #3 of 10 (permalink) Old 04-25-2018, 03:13 PM
Morningwood's Avatar
I have the same exact problem. I have had the ignition switch out a few times, all works good except the fork lock. Having them flush my brakes soon i'll have them look at it. They will either tell me it's normal or I need a new ignition for god knows how much.
Morningwood is offline
post #4 of 10 (permalink) Old 04-25-2018, 05:31 PM
geo8866's Avatar
Sometimes it's the simple things that are overlooked so don't be insulted by this question: Are you making sure the wheel is turned all the way to the left before you try to lock it? If it's not fully left, it is sometimes hard to lock the fork.
RGKen likes this.
geo8866 is offline
post #5 of 10 (permalink) Old 04-25-2018, 06:19 PM Thread Starter
Question
I have the forks to the left. Even tried moving it back & forth a little, no luck!!
nanook is offline
post #6 of 10 (permalink) Old 04-25-2018, 06:33 PM
NeverEnough's Avatar
Sounds like its not aligned right inside. Happened to me before because i took the ignition switch out without the forks locked. I had to take the switch out with the forks all the way to the left, and stick a screwdriver down there. There was very little movement, but i turned the screwdriver to the left just a bit and i could feel it kind of move back into place. Put the switch back in and i never had a problem after that. Lesson learned
Sent from my SM-J327P using Tapatalk
NeverEnough is offline
post #7 of 10 (permalink) Old 04-25-2018, 06:39 PM
https://youtu.be/7-QBH1SFyzo
This is the youtube video that i used to figure it out. Hope it helps!
geo8866 likes this.
post #8 of 10 (permalink) Old 04-25-2018, 09:43 PM
Swomack's Avatar
Good video that should help first timers for sure
Swomack
My Gallery / Click Below Link
Swomack is offline
post #9 of 10 (permalink) Old 04-25-2018, 10:56 PM
Swomack
It got me through a crisis. Apes installed, looked awesome, cant get the ignition to work?! That video saved me!
Swomack likes this.
post #10 of 10 (permalink) Old 04-27-2018, 10:33 PM
ChromeSpark's Avatar
Had this on mine, warranty repair. The took the switch apart, cleaned and lubed.
"It's a motorcycle, its not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
Question about tour pak lock/key kwcommando *General Road Glide Discussions/Pictures 7 01-28-2018 09:03 PM
13 and under Tourpak lock with 15+ key help Steelerdude1 *General Road Glide Discussions/Pictures 6 01-11-2016 09:49 PM
Tour Pack Lock W/Flat Key Lock. Bill-99RG *General Road Glide Discussions/Pictures 3 01-15-2015 01:16 AM
Getting a Lock to match my key rustyj671 Equipment-RG 4 04-02-2013 09:49 PM
Tour pak key lock JJSW1283 Aftermarket Accessories 6 11-24-2011 08:37 PM
