Holy cow need info before 5 o'clock - Road Glide Forums
post #1 of 12 (permalink) Old 06-04-2013, 12:45 PM Thread Starter
13HDGLIDE's Avatar
a buddy of mine just called and said he added new grips last night and now has no cruise and check engine light is coming on , I'm going to look at it this evening what do I need to look for or what should I expect when I get there ? surely he just pinched a wire maybe
13HDGLIDE is offline
post #2 of 12 (permalink) Old 06-04-2013, 12:48 PM Thread Starter
13HDGLIDE's Avatar
sorry guys I didn't notice where I put this it may need to be moved to correct sub
post #3 of 12 (permalink) Old 06-04-2013, 12:49 PM
ammojeff's Avatar
I agree with you that a pinched or loose wire in the controls, or he tugged on a spliced wire in his bundle I was amazed how many factory splices I had in my control wires on both sides when I had them out. Good Luck!
AMMO: Giving the enemy the opportunity to die for their country
ammojeff is offline
post #4 of 12 (permalink) Old 06-04-2013, 12:55 PM
It may be the brake light switch in the right side switch housing or the clutch safety switch in the left side switch housing, both of these will effect the cruise function.
post #5 of 12 (permalink) Old 06-04-2013, 01:02 PM
Check the codes for a twist grip sensor failure. P2138 or a cruise control P0577 Look for a pinched wire going into the bars.
rg_dave is offline
post #6 of 12 (permalink) Old 06-04-2013, 01:39 PM
I bet that's it. check for brake light when hand lever is squeezed
post #7 of 12 (permalink) Old 06-04-2013, 02:01 PM
RGKen's Avatar
If it is that switch the brake lights could be on full time and that will also cause the cruise not to work. If the bike thinks the brakes are on the cruise will not work.
2018 FLTRXS
RGKen is offline
post #8 of 12 (permalink) Old 06-04-2013, 02:26 PM
Gibson's Avatar
I agree on the brake light switch (unfortunately I am speaking from experience). I have done dozens of grips without forgetting to install the end of a zip tie between the lever and the housing, but all it takes is one to remind you. Most dealers keep them in stock for those of us that forget. If memory serves me right I believe they are about $45.00
Gibson is offline
post #9 of 12 (permalink) Old 06-04-2013, 02:36 PM Thread Starter
13HDGLIDE's Avatar
thanks gents I will post results tonight
post #10 of 12 (permalink) Old 06-04-2013, 05:15 PM
Forgot about that. If he didn't stick a ziptie in there I agree that's the best bet.
2013 Ultra
Pics here:
rg_dave is offline
Need info before spending money Mickeyv Do-IT-Yourself 5 09-11-2013 05:15 PM
The clock won't keep time owl1289 *General Road Glide Discussions/Pictures 34 05-30-2013 01:24 AM
stock clock danglide Audio 13 03-14-2013 11:24 PM
Holy Cow!! sportyguy69 ECM/Fuel Management systems 12 08-01-2010 08:23 AM
