Diagnostic code p0562 - Road Glide Forums
post #1 of 13 (permalink) Old 06-04-2013, 10:29 PM Thread Starter
spokanebagfan's Avatar
2012 rgc. Just put a t-max a dragula and andrews 57h in over weekend ran well initially and the voltage is intermittently dropping and the the battery light and engine light came on and pulled code. The voltage comes and goes. Checked ground and it looks fine. T- max looks fine and like I said the battery light and engine light come and go. The voltage w t down to about 10.5 and then goes back up and then back down. This happens mostly when it is hot. Any ideas?
spokanebagfan is offline
post #2 of 13 (permalink) Old 06-04-2013, 11:00 PM
Triplej's Avatar
The P0562 is a Low Voltage trouble code. Most likely a bad connection somewhere. Could be a loose or corroded cable either at the battery or other end of the cables. Start with checking for good connections at both ends of the cables and apply some dielectric grease to the connections. Also apply some of the grease to the T-MAX connections and any other connectors you may have messed with while doing the mods.
According to the Service Manual, Low Voltage generally indicates a loose wire, corroded connection, battery and/or charging system problem.
I would start with the cable ends and see what you come up with after clearing the codes. If you still throw the code you can then move on to checking the rest of the system.
Triplej is offline
post #3 of 13 (permalink) Old 06-04-2013, 11:11 PM
T-max doesn't want Dielectric grease on the ECM plug But putting it on the 02 sensor connection is OK. Did you have the Voltage regulator serviced according to the HD recall?
post #4 of 13 (permalink) Old 06-04-2013, 11:17 PM Thread Starter
Checked all the fittings and no issues. Ground and t max look good used dialectics grease for t max cleared codes and not sure what it could be could it be stator or regulator?
post #5 of 13 (permalink) Old 06-04-2013, 11:18 PM Thread Starter
Did the grease as you said but no I did not touch the regulator. Is there a recall?
post #6 of 13 (permalink) Old 06-04-2013, 11:20 PM
Triplej's Avatar
Thanks for that info on the T-max Mark, was unaware of that T-max fact on the grease. I wonder what their reasoning is.
Triplej is offline
post #7 of 13 (permalink) Old 06-04-2013, 11:26 PM
Triplej's Avatar
Here is a thread on the VR recall. You can go to the HD website and plug your VIN # in and see if your bike is affected.
https://www.roadglide.org/showthread....gulator+recall
Triplej is offline
post #8 of 13 (permalink) Old 06-04-2013, 11:30 PM Thread Starter
Thank you tripej
post #9 of 13 (permalink) Old 06-04-2013, 11:34 PM
2012 has a VR recall and if your bike already had it done there have been times when the VR will just go out even after a VR replacement.The dielectric grease application is in the T-Max instructions.
post #10 of 13 (permalink) Old 06-04-2013, 11:36 PM Thread Starter
Thank you sir.
How to Find your Diagnostic Trouble Codes ironmark Troubleshooting for Road Glides 42 05-03-2019 06:43 AM
diagnostic code b2016 whiskeyrider Audio 0 12-19-2015 11:22 AM
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
B1006, P0562, Battery light, Cel, Intermittinent charging? xbmxxx *General Road Glide Discussions/Pictures 7 03-20-2015 09:49 AM
Error Codes on TMax Diagnostic Code Page Q-Hog ECM/Fuel Management systems 4 06-30-2013 11:58 AM
