Any way to get the oil pressure reading like the older Rushmore bikes? - Road Glide Forums
 10Likes
post #1 of 12 (permalink) Old 07-11-2018, 12:50 AM Thread Starter
BigBlockBobby's Avatar
On the pre M8 rushmore bikes you could get an actual oil pressure reading on the info screen. Now it just says 'OK" or check oil. Any way to get a pressure reading like the older models? I'm going to add an oil pressure gauge if not.
BigBlockBobby is offline
post #2 of 12 (permalink) Old 07-11-2018, 06:21 AM
MightyWhitey's Avatar
Why? If itís OK....then itís OK. Itís just one more thing to stare at while your trying to enjoy your ride.
eddienelson likes this.
MightyWhitey is offline
post #3 of 12 (permalink) Old 07-11-2018, 11:37 AM Thread Starter
Years of turning wrenches it is just what I do. I like to be able to check hot idle and cruise pressure from time to time.
post #4 of 12 (permalink) Old 07-11-2018, 04:57 PM
On the one hand, I get it. Iím a full time wrench myself. But....on the other hand I donít get it. Itís a new bike with a warranty. Youíre not supposed to worry about that crap. Run it! If it breaks, let Ďem fix it.
Not trying to offend. Just conversating. Do what makes you happy, of course. Unfortunately I have only criticism for your plans......not an answer to your original question. Good luck though.
RGKen likes this.
post #5 of 12 (permalink) Old 07-11-2018, 05:09 PM
BB Bomber's Avatar
From what I understand, no, there is no way.
BB Bomber is offline
post #6 of 12 (permalink) Old 07-12-2018, 09:06 AM
Dice21's Avatar
There isn't, and it's stupid that they changed it. I want to know what the pressure is.
Buddy is a HD service manager. Lots of complaints about it, no fix.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #7 of 12 (permalink) Old 07-12-2018, 04:18 PM
VDeuce's Avatar
The only way is a mechanical gauge and it has been done on another forum.
VDeuce is offline
post #8 of 12 (permalink) Old 07-12-2018, 04:56 PM
RGKen's Avatar
These engines are more about oil flow than oil pressure. It is not like many other engines especially car engines where oil pressure is more important. Plus the oil sending unit can go bad and give you a false reading when everything is fine anyway. Been there, done that. ALL of the other non fairing bikes don't have an oil pressure gauge and you just ride them. If you really need it then add the OP gauge and have at it but I think you are overthinking it and taking away from the reason you ride in the first place. Ride safe!
eddienelson and Little Wing like this.
2018 FLTRXS
RGKen is offline
post #9 of 12 (permalink) Old 08-02-2018, 09:09 PM
eddienelson's Avatar
@RGKen you are dead on! The diesel engines today are about volume not pressure. I use to be that guy that thought you needed high pressure to fully lubricate but in all honesty the more pressure the better the chance of blowing a seal or gasket. Ill take volume over pressure any day. If its says OK then dont worry about it. That being said my really old outdated Rushmore bike has pressure readings and its a great tool to see fluctuation to tell if there is a problem or potential problem. So I guess what Im saying is deal with it and ride. If its not ok then you need to be concerned.
2016 RG Custom Vivid Black
eddienelson is offline
post #10 of 12 (permalink) Old 08-03-2018, 08:06 AM
Little Wing's Avatar
i was concerned about the lack of a gauge at first, too, but after reading about how the M8s CIRCULATE the oil for cooling purposes i don't see a problem. OK means OK
didn't somebody figure out a way to read oil temperature instead of ambient temperature though?
'18 FLTRX ē '04 BAR HOPPER ē '94 FLSTC ē THE BEST BIKE ...is the one you're on!!!
Little Wing is offline
Biggest Rushmore Improvement Over Pre-Rushmore Bikes??? 09Sharknose *General Road Glide Discussions/Pictures 15 02-14-2016 08:31 AM
Rushmore bars on pre Rushmore bikes Steelerdude1 *General Road Glide Discussions/Pictures 1 11-08-2015 03:02 PM
I like the way the 30 looks like its spinning backwards.... Quicksand General Off-Topic Discussions 8 12-24-2012 01:06 PM
