ABS light on no codes - Road Glide Forums
post #1 of 1 (permalink) Old 07-21-2018, 05:59 PM Thread Starter
pjbolo's Avatar
A couple of months ago i replaced my front ABS sensor due to an intermittent ABS light and Code.
that did not cure the problem!
Further troubleshooting i found a broken wire in the ABS harness connected to the front wheel sensor under the left front fairing.
I cut it out spliced and repaired end of that problem!
Riding out to PA from Mass last week about 200 miles into the trip the ABS light comes on while riding. Stopped and checked codes there are none? Cycled the ing switch ABS was flashing normal, start riding and it goes out but comes back on a short time later. Again checked codes and NONE?
Seems when you cycle the Ign sw its normal until you start riding BUT it's not throwing any codes for the ABS.
The only codes i got are B-1121 and B-1122 left turn and right turn output fault or open. All my lights are working correctly? Not sure why they're throwing codes
Has anybody experienced slimier issues with ABS
thanks, paul
pjbolo is offline
engine light on no codes help Roadking03 ECM/Fuel Management systems 1 09-16-2018 05:25 PM
15 FLTRX Vivid Black............No Security & No ABS maddmoe Road Glide Builds-Document your builds HERE --NEW 135 08-28-2016 12:30 AM
ABS and Tach codes shane_huskey Troubleshooting for Road Glides 2 07-25-2014 08:36 AM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 12:56 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
