at a loss with the front brakes!! Help plz - Road Glide Forums
 7Likes
post #1 of 20 (permalink) Old 08-16-2018, 01:51 PM Thread Starter
brhodea's Avatar
First off, I've got a '11 RGU with 62k miles. I bought it new so I know everything thats been done to it.
I was out for a short ride when the front brake lever got extremely hard to pull. I was able to free it up if I pulled hard enough. It'd be normal for a few miles then go back to hard to pull. I brought it to my indy, who is an excellent mechanic & has a great rep. in the area, he rebuilt the master cylinder, tried bleeding the system but found the ABS module valves weren't functioning correctly. He advised me to take it to the dealership because its a dealer only item, or I could bypass the ABS system altogether.
I decided not to deal with the dealership as I don't trust them, but I picked up a used ABS module from a '13 Ultra w/ 16k miles. The mechanic ended up draining the brake fluid several times to clear all the crap out of the lines. He also pulled both calipers & cleaned/lubricated them. this seemed to fix the issues, I picked it up & only got a couple miles down the road when the front brakes started grabbing so much i had to down shift just to maintain speed. I brought it right back, after it cools down he re-bleeds the brakes, everything seems to work fine until it gets back on the road & heats up, brakes start closing off again.
any tips on what to try next before I have him delete the ABS all together?
brhodea is offline
post #2 of 20 (permalink) Old 08-16-2018, 02:43 PM
RGKen's Avatar
How many times since you bought the bike have you had the brake system flushed?
2018 FLTRXS
RGKen is offline
post #3 of 20 (permalink) Old 08-16-2018, 02:52 PM
FDR's RGC's Avatar
If you didn't buy a new module then you bought someone else's problem.
FDR's RGC is online now
post #4 of 20 (permalink) Old 08-16-2018, 03:18 PM Thread Starter
brhodea's Avatar
It's never had the system bled until now. & only found out about the recall while dealing with all this. Dealership serviced the bike for the first 4 yrs & never even suggested it when i'd ask for a full service.
The module I bought works fine while hooked up to the bleeding machine. The original wouldn't function at all. The part came off a bike that was totaled from a minor accident, not from a braking issue.
brhodea is offline
post #5 of 20 (permalink) Old 08-16-2018, 03:28 PM
RGKen's Avatar
That is what I was guessing when I asked the question but let's not worry about that part anymore as it is over and done with.
When your indy replaced the module did he replace all the brake lines as well and do you know if he used DOT 4 brake fluid when he flushed and re-filled the system? If ANY of the rubber components have been contaminated with another type of brake fluid that will cause problems.
Swomack and Challngr72 like this.
2018 FLTRXS
RGKen is offline
post #6 of 20 (permalink) Old 08-16-2018, 03:32 PM
Stoic Joker's Avatar
Might should have given the dealer a shot before getting this far. When the ABS unit on my 10 took a shit the MoCo volunteered to covered the replacement cost of the unit ... And the bike was several years out of warranty at the time..
RGKen likes this.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #7 of 20 (permalink) Old 08-16-2018, 03:40 PM
James's Avatar
How was he bleeding the brakes and making the abs module function? Does he have a tech 2?
Without that, bleeding abs is a crap shoot, almost impossible if you start replacing modules or complete sections of line. I was successful twice after caliper replacements without taking it to the dealer. When I replaced the lines with stainless, not a chance. Luckily I spoke with the dealer when the abs recall came out and they said they would bleed it while doing the recall and didn't care if I just replaced the lines. So I bled it enough to ride to the dealer but it wasn't bled very well. Without a tech 2 and the ability the pulse the abs module, you will not have very good luck bleeding it.
James is offline
post #8 of 20 (permalink) Old 08-16-2018, 03:47 PM
James's Avatar
Oh yeah, I am with you on not trusting the dealer. The free abs flush was the only reason I went. Got the bike back and the radio didn't work. They washed it with water and the rubber aux plug was not in the radio. 1 hour later I was on my way. Got on the highway and the brakes sucked bad. That extra hour they kept me put me right in rush hour traffic, I just rode home pissed. Called them and said I was bringing it back first thing in the morning. 4 hours later, bike was back and brakes worked, they said they couldn't find a problem but the brakes magically worked. Then, my abs light wouldn't go off, they said the sensor is probably bad. Wtf wasn't it on before all of this?!?! I am tempted to bypass all the abs bs as well.
James is offline
post #9 of 20 (permalink) Old 08-16-2018, 03:55 PM Thread Starter
brhodea's Avatar
didn't replace any lines, i'm thinking the inside of the lines are deteriorating and blocking flow back
The MoCo has already given the solid no on helping. even though my warranty just ended last Jan.
brhodea is offline
post #10 of 20 (permalink) Old 08-16-2018, 03:58 PM Thread Starter
brhodea's Avatar
Yes he has the right equipment, I'm probably going to ask him to change the lines.
RGKen and James like this.
brhodea is offline
Help Plz!!! Blk Denium shagyluke Paint & Bodywork Section 10 03-18-2015 08:14 PM
Clutch in....... "CLANK"..? Plz Help! Scootin Tech Area 15 11-17-2013 02:27 PM
Inner Fairing repair help needed plz!! Trainwrecked Paint & Bodywork Section 8 01-12-2013 12:03 AM
Forgot FOB Help Plz jbrawkus *General Road Glide Discussions/Pictures 14 09-24-2011 01:26 PM
Plz help me find the thread?? jbrawkus *General Road Glide Discussions/Pictures 9 08-02-2011 06:15 PM
