Clutch Slipping - Road Glide Forums
 2Likes
post #1 of 13 (permalink) Old 09-16-2018, 08:04 AM Thread Starter
Dice21's Avatar
Clutch Slipping
So, yesterday I'm riding along the highway around 75 leading a run. We change lanes and I give it a bit of throttle. The bike revs like crazy, but speed doesn't increase. We get off and check my fluids, all good. Give it a little test on a side road, and I can almost redline it while barely moving. If I'm super gentle accelerating it seems ok. So I limped it home, and checked everything out again. Trans level is spot on, primary level is right where it's supposed to be.
This is on a 17 RGS with only 7k on it.
Anyone else have anything similar happen to them? If so, what fixed it?
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #2 of 13 (permalink) Old 09-16-2018, 08:26 AM
geo8866's Avatar
I am not an expert but I've heard others describe similar symptoms that turned out to be the sumping issue. Are you stage 3 or 4?
geo8866 is offline
post #3 of 13 (permalink) Old 09-16-2018, 08:51 AM Thread Starter
Dice21's Avatar
Neither. Motor is stock internally. I thought about sumping at first. But the motor is running perfect. I also thought it could be transfer from trans to primary, but that's not the case either.
I do know I'm not overly happy about it.
Dice21 is offline
post #4 of 13 (permalink) Old 09-16-2018, 09:27 AM
madmat's Avatar
Curious, keep us in the loop.
Good luck!!
18 RGS Bonneville Salt Pearl
madmat is online now
post #5 of 13 (permalink) Old 09-16-2018, 09:55 AM
Dragon Dude's Avatar
I installed cams in my 13 and the clutch started slipping with only 1300 miles on it. I did some research and decided to install the SE clutch plate and see if that helped. My stock clutch has been rock solid since the install. Simple install to try out and see if that works for you.
Dragon Dude is offline
post #6 of 13 (permalink) Old 09-16-2018, 02:38 PM
hoosierboarder's Avatar
Had a buddy with the same problem on a '13, his was WAY over serviced. After he drained & re serviced , he was good. Doesn't seem to be the case here, though. Maybe try to re-adjust the clutch first .
'09 Road Glide
hoosierboarder is offline
post #7 of 13 (permalink) Old 09-16-2018, 02:55 PM Thread Starter
Dice21's Avatar
It's a hydraulic clutch. Not really any way to adjust it. And it sounds like Harley probably won't cover it. Spoke to the Service Manager this morning. He happens to be a good friend of mine. So I'm guessing I'll be looking at replacement recommendations if they won't.
Dice21 is offline
post #8 of 13 (permalink) Old 09-16-2018, 03:36 PM
I'm behind the times!lol! That sucks. Hope you get it resolved without big expense.
'09 Road Glide
post #9 of 13 (permalink) Old 09-19-2018, 08:52 PM Thread Starter
Dice21's Avatar
Well, I got the bike back. It was the aftermarket clutch lever I put on a while back. Since the hydraulic clutch has no adjustment, the lever has to be made pretty precisely or the clutch will always be engaged just a little bit. And mine wasn't.
No clutch damage, and with the factory lever on it everything is good.
I'm glad it was something simple, but I guess it's something to watch out for on a system with no way to adjust anything.
Dice21 is offline
post #10 of 13 (permalink) Old 09-20-2018, 05:50 AM
Nutt2336's Avatar
Out of curiosity what aftermarket clutch level were you using?
I am my Brothers keeper.
Nutt2336 is offline
Slipping clutch craigp95 Engine Related 19 02-18-2016 05:45 PM
Hydraulic Clutch Slipping phillyrube Troubleshooting for Road Glides 3 05-05-2013 03:53 PM
2011 RGU Clutch Slipping brhodea *General Road Glide Discussions/Pictures 12 03-29-2013 01:28 PM
Clutch Slipping? PhrogFlyer Troubleshooting for Road Glides 17 03-11-2013 05:12 PM
stock 103 possible smoked clutch/slipping trans OuchMMC Engine Related 23 10-13-2012 09:29 PM
