Distance since last service - Road Glide Forums
 17Likes
post #1 of 34 (permalink) Old 11-06-2018, 02:42 PM Thread Starter
craigffb's Avatar
On the new GTS radio, does anyone know how to reset the Distance since last service? It's on the Engine Info page in the Information/Vehicle Status section. The only reference in the manual is
Reset Last Service
Please see Harley-Davidson dealer to have the Distance Since Last Service odometer reset.
craigffb is online now
post #2 of 34 (permalink) Old 11-06-2018, 02:45 PM
gldlver's Avatar
Reset Last Service
I think you answered your own question
gldlver is offline
post #3 of 34 (permalink) Old 11-06-2018, 03:00 PM Thread Starter
craigffb's Avatar
There's got to be a way to rest it without going to the dealer. If not that's some BS, unless they aren't going to charge me to do it...
geo8866 likes this.
post #4 of 34 (permalink) Old 11-06-2018, 03:51 PM
Only the dealer can reset it and it is a pain for them. I ask one of the service tech's at my dealer and we went and looked it up. The bike has to be connected to there electronic service tool , the key fob has to be out of range of the bike. Then it is multiple steps for the tech to go through to reset it. I do my own service so told them when I trade it in for the next bike they can reset it then. HA HA !! I also have a BMW and it has to be reset by the dealer as well but there is an aftermarket code reader you can buy for about $300.00 and do it your self. I don't expect to see an aftermarket device for the Harley because they made it very complex to reset even with there tools. I would expect the Harley tech's to need to pull out the service manual each time they do an oil change to reset the damn thing. Those of you that let the dealer service your bike should check to see if they even bother to reset it at the service.
Oilcan is offline
post #5 of 34 (permalink) Old 11-06-2018, 03:58 PM
BobRG15's Avatar
The online manual states to:
1) turn Off the Ignition
2)wait 15 seconds
3)turn on acc
4)holdpower/mute button till service menu is displayed
5)Select Reset
6)Select mileage reset
7)Select Yes
Bruce00 and geo8866 like this.
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
BobRG15 is online now
post #6 of 34 (permalink) Old 11-06-2018, 04:03 PM
Yes that is the instruction for the tech after it is connected to the HD electronic service tool and put in service mode.
Oilcan is offline
post #7 of 34 (permalink) Old 11-06-2018, 05:00 PM
MightyWhitey's Avatar
And that is a pain to accomplish?
geo8866 likes this.
MightyWhitey is offline
post #8 of 34 (permalink) Old 11-06-2018, 05:40 PM Thread Starter
craigffb's Avatar
I found this on "another" message board:
It's done through the maintenance menu on the Boom Box. To enter maintenance mode, let the bike sit without messing with it for several minutes. 5 minutes seems to work. While holding one finger on On/Off (lower right) of Boom Box, depress trigger switch (left handlebar). Release trigger switch when Boom Box displays start up screen but continue to hold finger on On/Off of Boom Box. The usual warning message will display. Continue to hold the On/Off, be patient, until the Maintenance screen comes up. Now be carefull. You can screw stuff up (like your engine software) if you're careless. Scroll down to the reset option and select that. This will give an option to reset mileage since last maintenance. After reset you can back out or simply use the trigger switch to turn the Boom Box off. This is also a second way to view and clear DTCs. I had to try several times to get into maintenance mode, so be patient. It does work.
Bruce00 and BobRG15 like this.
post #9 of 34 (permalink) Old 11-06-2018, 05:41 PM
geo8866's Avatar
I can't believe they would design the system where the owner can't reset the service reminder. If they did, it's fucking ridiculous.
ALMOONEY and craigffb like this.
geo8866 is offline
post #10 of 34 (permalink) Old 11-06-2018, 06:04 PM Thread Starter
craigffb's Avatar
2)wait 15 seconds
3)turn on acc
5)Select Reset
7)Select Yes
What on line manual did you find this one in?
First Full Fluid Service since Purchase BILBO Fluids and Lubricants 18 03-19-2014 02:42 PM
23" Tire to fender Gap distance twistedglide Wheels and Tires 7 08-06-2012 11:29 AM
Keep your distance! Mcrider996 Safety Area 9 05-07-2012 08:53 PM
Headlight distance? cwdouble Road Glide Specific Discussions 14 01-23-2012 11:33 PM
