Hydraulic clutch master cylinder sight glass - Road Glide Forums
 4Likes
  • 1 Post By HogWart
  • 1 Post By HogWart
  • 1 Post By wevsspot
  • 1 Post By smitty901
post #1 of 9 (permalink) Old 11-13-2018, 03:59 PM Thread Starter
There isn't one on my 2018 Road Glide Special.
I guess the only way to check the fluid level is to remove the cover and gasket. That sucks. The FM is strangely quiet on checking the fluid level. Is there something in the reservoir that would tell me where the level should be?
- HogWart -
2018 FLTRXS Vivid Black: "NightnGail"
HogWart is offline
post #2 of 9 (permalink) Old 11-13-2018, 06:37 PM
Pags63's Avatar
Hope this helps you
File Type: jpg Screenshot_20181113-193654_Adobe Acrobat_1542155846953.jpg (265.8 KB, 58 views)
Pags63 is offline
post #3 of 9 (permalink) Old 11-13-2018, 06:54 PM
geo8866's Avatar
I'm pretty sure you have to remove the cover to check the level. That's what I did. Make sure the reservoir if completely level before removing it.
geo8866 is offline
post #4 of 9 (permalink) Old 11-14-2018, 10:30 AM Thread Starter
Originally Posted by Pags63 View Post
Hope this helps you
It does!! Thanks! I can't believe I didn't find that in the FM.
Need. New. Glasses....
- HogWart -
HogWart is offline
post #5 of 9 (permalink) Old 11-14-2018, 10:32 AM Thread Starter
Yup. But I can't believe HD didn't provide a sight glass. DOT 4 sucks moisture from the air (a bad thing), so opening the reservoir means some moisture will get in there. Ugh.
geo8866 likes this.
- HogWart -
HogWart is offline
post #6 of 9 (permalink) Old 11-14-2018, 02:00 PM
On my ‘16 RGU I have a spyglass on the right side of the reseivor. Because the clutch oil gets very dirty though usage it can look as black as the reseirvor itself and get masked
To see the level, with the bike upright, turn the steering all to the right to level the reseirvor and you should see the level just in the middle of spyglass.
Beaver is online now
post #7 of 9 (permalink) Old 11-14-2018, 02:15 PM Thread Starter
Unfortunately, I guess H-D eliminated the sight glass on later model Road Glides...
geo8866 likes this.
- HogWart -
HogWart is offline
post #8 of 9 (permalink) Old 11-14-2018, 02:53 PM
wevsspot's Avatar
Correct.
geo8866 likes this.
wevsspot is offline
post #9 of 9 (permalink) Old 11-14-2018, 03:56 PM
smitty901's Avatar
If it is not leaking the level is fine don't open it needlessly.
geo8866 likes this.
smitty901 is offline
Brake and Clutch master cylinder brackets 2015 RGS Boostn Controls & Handlebars 8 04-02-2015 06:24 PM
Clutch/Master Cylinder Reservoir Covers The Volusianator Controls & Handlebars 2 11-30-2014 08:06 AM
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 02:46 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 12:07 PM
Hydraulic Clutch Chrome Master Cylinder HELP Hayabusa1967 Controls & Handlebars 2 09-25-2011 09:21 PM
