Red Light on after battery change. - Road Glide Forums
post #1 of 12 (permalink) Old 03-30-2019, 08:54 AM Thread Starter
FeMoRg's Avatar
I changed the battery on my 2016 RG and after the change out the red light is on and I have no brake lights. Running lights work and blinkers work. Cruise control doesn't work. It does have LED's installed. It is giving me a code for ECM, BCM, and speedometer. It cranks and runs fine. Is there a reset that can be done or could low battery in fob cause the issue...I'm lost on this deal.
FeMoRg is offline
post #2 of 12 (permalink) Old 03-30-2019, 09:09 AM
i think that a run with the DIGITAL TECHNICIAN at dealership will fix the issue. it is possible that the BCM memory connection went lost.
with DT they will be able to troubleshoot the codes as well
Beaver is online now
post #3 of 12 (permalink) Old 03-30-2019, 09:53 AM
BH#103's Avatar
Cruise control probably does not work because the brake lights so not work. Double check your work and inspect your fuses first. You say red light is on, what red light?
"SLIVER"
BH#103 is offline
post #4 of 12 (permalink) Old 03-30-2019, 10:41 AM
Thermodyne's Avatar
Did you turn the key on and pull the main fuse before you swapped the battery?
Thermodyne is offline
post #5 of 12 (permalink) Old 03-30-2019, 02:31 PM Thread Starter
FeMoRg's Avatar
The red light that is on the speedometer next to the cruise light
FeMoRg is offline
post #6 of 12 (permalink) Old 03-30-2019, 02:32 PM Thread Starter
FeMoRg's Avatar
No I didnt...
FeMoRg is offline
post #7 of 12 (permalink) Old 03-30-2019, 02:33 PM Thread Starter
FeMoRg's Avatar
No I didnt...
FeMoRg is offline
post #8 of 12 (permalink) Old 03-30-2019, 04:41 PM
BH#103's Avatar
The weather is still pretty shitty here in Illinois so I have not been on my bike long enough in recent days to have memorized what red light is next to the cruise light on the speedometer. Maybe a picture, is it the battery light?
"SLIVER"
BH#103 is offline
post #9 of 12 (permalink) Old 03-30-2019, 04:46 PM
BH#103's Avatar
"SLIVER"
BH#103 is offline
post #10 of 12 (permalink) Old 03-30-2019, 05:26 PM
Thermodyne's Avatar
No I didnt...
I'm thinking that might be what caused the issue. Assuming that everything went correctly with the battery and all the cables got back where they belong.
You might try turning it on and pulling the main. Give it a few minutes and put it back in, see what happens.
Battery Change and Alarm System+ Instructions? BDMastiff Do-IT-Yourself 5 05-18-2016 06:05 AM
Blue led bling light set (used) HUTMO Sold 6 05-05-2016 10:07 PM
wonder bar light on my glide dosnt light my ride is a glide Troubleshooting for Road Glides 1 07-02-2012 07:18 AM
New Bike - Engine & Battery Light pscan5150 Troubleshooting for Road Glides 15 06-08-2012 05:02 PM
Custom Dynamics Genesis II LED Tail light review Sonar_Chris *General Road Glide Discussions/Pictures 6 11-11-2009 05:19 PM
