switch covers - Road Glide Forums
post #1 of 5 (permalink) Old 02-07-2011, 01:15 PM Thread Starter
firerodder's Avatar
switch covers
Okay, switch covers..... How the hell do these damn things come off?? I have loosed every screw that can be found and yet the right one doesn't want to let go. I have jacked with the right side so long, I haven't even got around to getting mad at the left yet. I have been careful not to break anything, but my fuse is about to burn out and I'm sure the stock switch housing will be the victim of the assult. Anyway, I'd like to figure this thing out with the assistance of any of you that would like to add your advice. If there is a video on the web that can walk me through it, that'd be great. Youtube had some posts, but I felt they were edited to remove the cussing. Thanks in advance for any words of wisdom.
firerodder is offline
post #2 of 5 (permalink) Old 02-07-2011, 03:26 PM
Gadgetech's Avatar
Did you loosen the clamp thats on the opposite side of the switch housing from the grip?
2017 RGU Black Quartz
2014 Ducati Multistrada Granturismo
Gadgetech is offline
post #3 of 5 (permalink) Old 02-13-2011, 06:13 PM Thread Starter
firerodder's Avatar
Yes, all screws where taken off and it seemed as though there was something still holding the bottom on. The wires were tight, but an inspection with a super bright LED flash light could find no additional hardware.
post #4 of 5 (permalink) Old 02-24-2011, 03:27 PM
Not sure whether you'd solved the problem yet, but, I changed them out recently and aside from stuffing the wire wrap back in for reinstall, it wasn't too bad. I, too, thought I'd missed something because it still wouldn't come apart when all the screws were removed. Grab each half and muscle it apart! You won't break anything. Pretty simple.
Dodger is offline
post #5 of 5 (permalink) Old 02-25-2011, 11:19 AM
Make sure you remove the brackets that hold your brake & clutch levers the mirrors and front brake reservoir are mounted to those bracket also . Be careful putting things back together because it is very easy to pinch wires .
Chrome Switch Covers G Aftermarket Accessories 36 05-04-2019 07:39 PM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 08:18 AM
New Ignition Switch covers precisionbillet Precision Billet Products 28 05-14-2013 12:33 PM
stock switches, wiring & stock switch covers Pistokcha Controls & Handlebars 0 08-25-2012 08:35 PM
chrome switch covers. gja Controls & Handlebars 2 02-04-2012 05:37 PM
