Primary gasket/seal - Road Glide Forums
post #1 of 13 (permalink) Old 08-02-2013, 11:07 AM Thread Starter
WoodyHD's Avatar
Primary gasket/seal
Getting ready to change the oil in the primary and I guess HD changed from the round disk to just a round rubber seal for the cover. Anyone know if the disk still works (I have an extra one of those), looks like it might. It's a 103, but I don't believe that would matter...
Thanks,
Woody
2011 Vivid Black FLTRX 103
WoodyHD is offline
post #2 of 13 (permalink) Old 08-02-2013, 11:33 AM
PGR
PGR's Avatar
Thanks,
Woody
You can use either. I am still on my original "O" ring seal. I've done my primary oil 3 times with no leaks. I'll be doing my 40,000 mile in a month or so. I plan on using the original ring yet again.
If you use the ring over, just make sure to clean the surfaces and the ring well before assembly.
If you change to a custom derby cover, then you have to use the disk, unless it has the groove for the ring.
Ron..........................
PGR is offline
post #3 of 13 (permalink) Old 08-02-2013, 11:47 AM Thread Starter
WoodyHD's Avatar
Thanks Ron, that's what I figured. I plan to use the "O" ring seal again too, just wanted to make sure I had a back up in case it was damaged. 'Preciate it!!
WoodyHD is offline
post #4 of 13 (permalink) Old 08-02-2013, 12:34 PM
Yep, have used the same this side clutch, gasket @16 times or more, never leaked, still have the back-up thrown one of chest from over 8yrs ago, hell they even reused it after warranty work,cheap SOBs
reds4 is offline
post #5 of 13 (permalink) Old 08-02-2013, 12:52 PM
PGR
PGR's Avatar
16 times would be 160,000 miles...... and they're the cheap SOB's?
PGR is offline
post #6 of 13 (permalink) Old 08-02-2013, 01:15 PM
Memphisglide's Avatar
LOL Now thats some funniness right there!
2016 Road Glide Special - Black Quartz
Memphisglide is offline
post #7 of 13 (permalink) Old 08-02-2013, 01:42 PM
I'd say thrifty, and will also answer to A$$hole, or just tell em to drive that middle finger up their....
I change the primary every time I change oil, prety much, drain pans already there, shes' got over 88000 miles on her
math not your strong suit
reds4 is offline
post #8 of 13 (permalink) Old 08-02-2013, 01:52 PM
PGR
PGR's Avatar
Primary and trans every 10,000 like it says in the maintenance schedule
https://www.harley-davidson.com/en_U...G/file-18.html
So using the maintenance schedule .... 16 X 10,000 ......
PGR is offline
post #9 of 13 (permalink) Old 08-02-2013, 02:44 PM
Used to change the oil every 2k but now more like 3-3.5k, somewhere back @ 12k the dealer put a new one (guessin) cause they gave me one back, and this one's the same one. when the tensioners came unglued @ 84k they put the same one back in, watched em. Now the tranys only been changed 4x, shhh, only I do the fluids as my other bikes, RG primary always a lil greyish from the clutch an such, rather be doing that right now than this (work, shhh) and it's pissy rainin here. Should've saved the MT beer cans to prove uh
reds4 is offline
post #10 of 13 (permalink) Old 08-02-2013, 03:01 PM
PGR
PGR's Avatar
I used to do the 2500 mile oil changes. Then I sent a couple of samples to Blackstone labs. They asked me why I was sending them virtually new oil. So I started doing what the manual says, and did 5K...... sent in another sample, and they told me I could extend that even more if I wanted to. But 5K is long enough that it doesn't seem like I'm swapping oil every 2 weeks. It's more like every month and a half.
Isn't it always raining there? I was at Ft Lewis for a while. I think I saw the sun a couple of times, but it might have been wishful thinking.
PGR is offline
Wanted: GASKET/SEAL that is used between the Fuel Injector electrical Connectors Wood Wanted! (Buy or Trade) 3 12-07-2017 10:22 PM
Primary Cover gasket question Still Grumpy Do-IT-Yourself 10 10-11-2012 09:06 PM
Primary gasket. Mike Jesse Engine Related 8 03-19-2012 11:17 AM
If the weather seal does not seal, what is the point?? Govdog76 Aftermarket Accessories 3 02-21-2012 09:48 AM
Inner primary seal vinchenz07 Troubleshooting for Road Glides 5 04-30-2010 11:00 PM
