Just upgraded to the shark a month ago from FLHRC, and I have noticed that the engine temp on the shark seems to get hotter faster riding stop and go around town. The engine temp I am referring to is the one displayed on my PV which comes from the ECM. The other day on a short ride I was at a red light and temp was 298F. I just would like to know what is the temp range at which I should start to be concerned. Warmed up on the HWY I average around 258F, but around town it quickly gets close to 300F in traffic.
I don't know "how hot is too hot?" but I do know that my 2012 RGU gets hotter than any other bike I have owned recently, and that would be 5 others. It gets hot in town, it gets hot on long rides, it just flat can't move air through the system and gets hot. I put true duals and a Stage 1 on my last 103" and I can't get that setup on this RG fast enough!
I replaced header in week two. I had forgotten how hot the stock header got. The setup I have now is identical to the one I had on my 2011 FLHRC. Just seems indicated temps rise faster and are close to 300F riding around town. Has not gone above 300 yet, I just want to know if 300F is close to where I should be concerned, or what the default temp is before a cylinder shuts down for cooling??
I installed a fan & new oil cooler as well as a temp gauge. At 200 degrees the fan comes on, even if I'm riding at highway speed. It seems to stay at 230 unless I really hit traffic. Yesterday was very hot and I was caught in bad NY traffic. It went up to 270.
I removed the cat from the headers and am running richer the engine richer.
Oh, I almost forgot. Before I had the headers removed and ran richer (in other words the bike was bone stock) I had the bike shut down on me in gridlock traffic. Cops were there so I couldn't white line. So all of a sudden the bike started running very rough. As I pulled over it shut down. No, I didn't have the temp gauge yet so I couldn't tell you what temp. But boy was it running hot.
I was told that the twin cams run alot hotter than previous motors for whatever the reasons. I had the same concerns when i put the oil temp gauge in a few years ago. I was told they will and do run about 300° and better. When my cylinder shuts off in traffic its usually about 240ish. Was also told when they tune the bikes they get them well over 300°. All of this was told to me by a dealer tech so take it for what its worth.
I'm pushing 6000 miles on my 2013 RGU. I very, very seldom runs above 230 and I have seen 250 only once. I don't drive in the heavy stop and go traffic, pretty much totally country riding and interstate. Went ot SWIII and it was hotter than all get outs, thats when I hit 250. I have the stage I with ceramic pipes. Just FYI. Also, I average 48-50 mpg, sometimes 52. I used the Power Vision Basic to tune it. Maybe my oil temp guage is off?
Stock mine use to run hot at times, I did 2 things that solved the problem, oil cooler with fan and engine cooling fan from www.wardspartswerks.com fcs cooling fan.
The bikes normal engine tmp at the heads can be 230/298 temp And that all depends on a few things like traffic, tune, and how you ride your bike,
Few things you can do to help.
1. oil cooler and good syn oil like mobil 1 20/50
2. EFI tuner and someone who knows how to tune.
3. Try to avoid stop and go traffic
4. Get a jims fan on the heads or something like that.
5. A cam with alittle more over lap will help
I put a dog dish on mine that seemed to cool the engine down a little. Seems to direct more wind on the engine. You have to be moving tho. Of course this is being judged by ass heat.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
