Voltage not stable - need help - Road Glide Forums
post #1 of 5 (permalink) Old 08-19-2013, 10:57 AM Thread Starter
Hi guys, my glide have been experiencing voltage instability on the volt meter for the pass month. The voltage will just ramp up to 16v with the speedo and tacho meter + HK stero set blacking out, at this stage the cruise control also stopped working.
Previously, the volt meter will fluctuate between 12v, 14v, at times 10v. The check engine and oil light from the dash will light up once the voltage is low. I have sent to the dealership to troubleshoot the problem. The voltage regulator and stator has been changed and the problem still persists.
What seems to be the problem?...
BTW, my glide is [email protected] RGC with 8000miles on it. Appreciate you advise..
LMF123 is offline
post #2 of 5 (permalink) Old 08-19-2013, 12:41 PM
You need to check your wiring harness from the voltage regulator out and make sure the mating connectors are clean. Use dielectric grease on the connectors.
Check your grounds up on the front forks. Make sure the battery ground is clean as well.
This almost sounds like you are having a bad connection since the regulator has been replaced. If the ground is not good, the regulator doesn't have a reference for the voltage. With a poor or floating reference (possibly to to a loose or dirty ground connection), the voltage will "float" to different levels and cause significant problems.
If the bike is a 2012 (read [email protected] in your post), then it is under warranty so don't spend a lot of time on it. Let the dealer figure it out and fix it for you.
Captain13 is offline
post #3 of 5 (permalink) Old 08-19-2013, 01:44 PM Thread Starter
Thanks Captian13, your suggestion make great sense, I have noticed a lot of road grime around the connectors, maybe due to leakage from changing the oil filter at the dealership.
Thank you and appreciate your help!
LMF123 is offline
post #4 of 5 (permalink) Old 08-19-2013, 02:25 PM
DOOFUS's Avatar
I've had 2 stators cause issues similar -- you'll know when the stator goes -- wow what a smell.
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #5 of 5 (permalink) Old 08-19-2013, 03:19 PM
tdkkart's Avatar
Last time i had one of those go the neighbor came over asking what the hell that smell was.....
tdkkart is offline
Measuring voltage out of amp to determine watts to speakers- help scottrgs Audio 5 04-03-2017 10:57 AM
New HD to the stable, but not a shark stripclub General Off-Topic Discussions 14 10-17-2014 03:22 PM
Voltage issues, need some ideas MShell Troubleshooting for Road Glides 27 06-23-2014 07:17 PM
help!! voltage fluctuates on guage suicidecj5 Tech Area 14 10-01-2013 07:25 PM
New horse in the stable - wife got a bike CHAINSAW General Off-Topic Discussions 35 11-08-2010 01:50 PM
