Available Wattage for Accessories? - Road Glide Forums
post #1 of 2 (permalink) Old 05-01-2011, 09:02 PM Thread Starter
Hi. I'm a new RGU owner, and was curious if anyone knew the amount of available wattage for accessories (like heated gear) on the 2011. I know HD upped the alternator output in this model, but the owners manual doesn't really tell you what the "base" wattage draw of the motorcycle is and what's left over for accessories.
If anyone knows the answer, it would be appreciated.
Thanks,
Al
Southern NH
mdwar2005 is offline
post #2 of 2 (permalink) Old 01-18-2012, 12:10 AM
I have a feeling that 20amp would be for ignition 10 amp for the headlights and so you are left with about 25amps for accessories. If you are so inclined you can always add in a delco or delphi single wire alt and run it off your primary... I saw a conversion one time but can't remember manufacturer
timmcgraw67 is offline
Double up wattage on head unit outputs? XM reception? Lunchmeat79 Audio 1 07-24-2014 11:12 PM
What wattage HID are you running? SilverGhost Lighting 7 01-13-2013 10:46 AM
Higher wattage bulbs!!! flyingpig Lighting 10 07-25-2011 06:18 PM
Mounting bar accessories w/o the use of brackets Sincecrazy Do-IT-Yourself 7 03-17-2011 09:23 PM
2009 road glide - tons of accessories rippedglide Classifieds Archive (3 months old+) 6 06-13-2010 08:34 PM
