Headlight Change? - Road Glide Forums
post #1 of 21 (permalink) Old 05-05-2011, 10:54 AM Thread Starter
Headlight Change?
What's involved in replacing the headlight bulbs? It doesn't look to me to be "intuitively obvious".
mdwar2005 is offline
post #2 of 21 (permalink) Old 05-05-2011, 11:23 AM
The only way I know of to change or replace the headlight bulbs would be to remove the outer fairing. I know that removing the outer fairing is required on the 08 and earlier models, I don't know if HD made it easier on the newer models.
post #3 of 21 (permalink) Old 05-05-2011, 11:28 AM
Shrug's Avatar
You can pop the headlight bezel out with a flat head screwdriver and access the lights. The entire headlight housing can be quickly removed without removing the fairing. It's really simple, but I recommend getting a service manual. It will come in very handy when you need it most.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #4 of 21 (permalink) Old 05-05-2011, 11:57 AM
I knew that HD made a design change to the headlight assembly on the newer models but I was not sure if the bulbs could be changed without removing the outer fairing. I do know that if you have a 08 or older models you will need to remove the outer fairing because there is no way to remove the headlight assembly without removing the outer fairing.
post #5 of 21 (permalink) Old 05-05-2011, 12:04 PM Thread Starter
Perfect - thanks a bunch, and yes, the Service Manuals are on the top of my "NEED" list. The stock lamps are much too dim, so they're coming out and Philips X-tremes are going in.
post #6 of 21 (permalink) Old 05-05-2011, 12:36 PM
Shrug's Avatar
Oops. Good catch Mark. I failed to specify newer Roadies.
Shrug is offline
post #7 of 21 (permalink) Old 05-05-2011, 12:44 PM
Thanks! Sometimes it would help if the original poster would specify the year of the bike .
post #8 of 21 (permalink) Old 05-05-2011, 04:43 PM Thread Starter
Is 'dat a hint???
________________
Al
Southern NH
2011 Road Glide Ultra
2005 Concours
post #9 of 21 (permalink) Old 05-05-2011, 05:56 PM
NakedSnowman's Avatar
Got mine a few days after I bought my '10.....Very handy and no more lost pages or greasy ones either....
http://motors.shop.ebay.com/Parts-Ac...c0.m282&_rdc=1
NakedSnowman is offline
post #10 of 21 (permalink) Old 05-05-2011, 06:22 PM
BDMastiff's Avatar
I think that Chainsaw has a video on how to remove the headlight. It's very easy; in fact, when you remove your faring it's easier to put it back on the clip if you remove the headlight assembly and put your hand through to clip it on.
1996 Fatboy
BDMastiff is offline
To change or not to change them, that is the question Steelerdude1 *General Road Glide Discussions/Pictures 2 07-18-2016 06:41 PM
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 08:50 AM
Headlight change vs. fairing removal ODA CDR (RET) Road Glide Specific Discussions 44 01-16-2012 03:51 PM
Shifter Rod Change dklanecky Aftermarket Accessories 8 10-23-2010 10:33 AM
Change your look BillyBob *General Road Glide Discussions/Pictures 0 11-28-2009 07:28 PM
