Sometimes the bike will not start first time - Road Glide Forums
post #1 of 6 (permalink) Old 09-13-2013, 11:19 PM Thread Starter
scubaz71's Avatar
I was wondering what the issue is? Sometimes the bike will not start the first time. i flip the button to run, turn ignition on, what for the ACR to release and the light to off and then I hit the start button. And all I here is clunk, like someone jammed a screwdriver in the starter, then the fuel pump kicks on again and goes through the cycle. Then when I hit the start button the bike fires right up. This has happend on a cold start and also after a gas stop. It also happened before and after the T-max install. The regulator has been replaced because of the recall and it does not do it all the time it is sporadic. Any help would be of great assistance.
Thanks,
Steve
Traded- 2012 BBP FLTRX, Tmax, Heavy Breather,Dragula, TW222 cams, swinebox.
Current-2016 CBP Ultra,race tuner,chisel intake,agitators and started the blackout process
scubaz71 is offline
post #2 of 6 (permalink) Old 09-14-2013, 05:54 AM
TimmyG's Avatar
Ki.da sounds lime your acr
TimmyG is offline
post #3 of 6 (permalink) Old 09-17-2013, 03:38 PM
There can be a few things going on there when the bike cycles it sprays a small amount of fuel into the systems to help fir it up. It could be dry what I mean is it may need more fuel at start up because it sounds like it will fire up after second try.
On the tmax that is call initial fuel pulse.
Also make sure you check your tmax for firm ware up grade.
DragoBikeWorks is offline
post #4 of 6 (permalink) Old 09-17-2013, 04:55 PM
Louisville Joe's Avatar
You just described perfectly my circumstances since installing my Tmax. I know it ain't gonna cold start on the first try. So the first time I hit the button I don't let it crank--just hit it and let off. 2 seconds later I hit the button again and it fires right up--this is on cold starts. On hot starts it starts just as soon as I touch the button for only a fraction of a second.
Louisville Joe is offline
post #5 of 6 (permalink) Old 09-17-2013, 06:04 PM Thread Starter
scubaz71's Avatar
Thanks fellas. Frank can I adjust the amount of fuel sprayed at start up or is that something that is programmed into the map? If it iis adjustable what should I set it at? I will check the firmware this weekend. Thanks.
scubaz71 is offline
post #6 of 6 (permalink) Old 09-18-2013, 07:26 AM
yes you can is under basic settings tmax
my bike sometimes has a miss cape breton Troubleshooting for Road Glides 1 08-15-2015 07:47 AM
Long time rider, first time Harley owner Partsman New Members Welcome Area 50 04-11-2013 03:38 PM
Hit the Start Switch Nothing Sometimes philmartin *General Road Glide Discussions/Pictures 38 01-30-2013 08:55 PM
Long time lurker, first time owner! dmarvin79 New Members Welcome Area 41 10-21-2012 06:21 AM
Long time HD rider first time RG rider xshovelfreak New Members Welcome Area 15 08-08-2011 04:10 PM
