help!! voltage fluctuates on guage - Road Glide Forums
post #1 of 15 (permalink) Old 09-30-2013, 03:43 PM Thread Starter
I have a 2011 rgu and while i ride my voltage stays at 14 plus or minus 1 ,but at a stop it goes to 12 volt . Is this normal or do i have an issue coming? thanks in advance.
suicidecj5 is offline
post #2 of 15 (permalink) Old 09-30-2013, 04:06 PM
Louisville Joe's Avatar
My '13 runs 14.5 at speed, drops during idle, not sure to what, but I think that kind of fluctuation is normal. Hope so, mine has been like that since last November, hasn't caused any problems.
Louisville Joe is offline
post #3 of 15 (permalink) Old 09-30-2013, 04:14 PM
zemo1017's Avatar
Mine has been doing that since day one with no issues.
zemo1017 is offline
post #4 of 15 (permalink) Old 09-30-2013, 04:58 PM
tdkkart's Avatar
Perfectly normal, especially if someone has dropped the idle speed setting down trying to get the "potato" sound out of it.
tdkkart is offline
post #5 of 15 (permalink) Old 09-30-2013, 05:27 PM
You really need to check it with a multi-meter, if you don't have should get, easy to do, and a troubleshooters best friend, there are threads on here to show how...... with that said, mines slow to drop when off, and I know everything right with....... ........ ...... & ..cause meter verifies
reds4 is offline
post #6 of 15 (permalink) Old 09-30-2013, 05:41 PM
tmd
Check it at the battery with a voltmeter. If its truly dropping to 12vdc then the battery is going bad. Ask me how I know.
tmd is offline
post #7 of 15 (permalink) Old 09-30-2013, 10:11 PM
JacktheBagger's Avatar
agree with tmd , the gauge isn't very accurate , check with a meter across the terminals , should be close to 13 volts on the low side , at idle , run it up to 2000 or so , such read high 13's - low 14's
since ya don't have three hands , I put alligator clip extensions on my meter leads , so's I could run the throttle up
my stator went south a few months ago , my only notice was , once or twice , the gauge dropped to 12 at 75 mph for a few moments ..
JtB
2011 Ultra
JacktheBagger is offline
post #8 of 15 (permalink) Old 09-30-2013, 10:57 PM Thread Starter
it doesn't drop while riding. it stays at 14. it only goes to 12+- while sitting at a light.
post #9 of 15 (permalink) Old 10-01-2013, 07:40 AM
Take your seat off and check the battery with a volt meter. To be 100% sure you see the same thing. Do you have any extra lighting etc on the bike. Idle should be around 1000.
DragoBikeWorks is offline
post #10 of 15 (permalink) Old 10-01-2013, 08:45 AM
This is normal. Check everyone else bike. The voltage is always higher while the bike is being ridden down the road as opposed to sitting and idling.
HogPro is offline
Audio fluctuates Xman247 Audio 1 05-28-2016 12:11 PM
Volume Fluctuates sdjiggs Audio 12 09-18-2015 02:20 PM
guage cluster / fairing izzi 75093 *General Road Glide Discussions/Pictures 6 10-18-2011 12:08 PM
Oil temp guage dbhwt Aftermarket Accessories 4 03-11-2011 08:53 AM
Guage bezel, visor for speedo/tach? Sincecrazy Aftermarket Accessories 0 03-24-2010 06:06 AM
