Oil leak - Road Glide Forums
post #1 of 22 (permalink) Old 09-30-2013, 05:51 PM Thread Starter
Admin
BillyBob's Avatar
Oil leak
Well I had an oil leak for the last couple of months and the bike has been looked at by the dealer 3 times each time they think they've fixed it. Anyway not sure what to do next, may take to an independent next to see what he says. It did start after a new starter was installed but apparently they have looked and repaired that seal. I'll post a photo- any input woul be helpful.
BillyBob is offline
post #2 of 22 (permalink) Old 09-30-2013, 05:57 PM Thread Starter
Admin
BillyBob's Avatar
Sent from Motorcycle.com App
BillyBob is offline
post #3 of 22 (permalink) Old 09-30-2013, 05:58 PM Thread Starter
Admin
BillyBob's Avatar
Here are some photos
BillyBob is offline
post #4 of 22 (permalink) Old 09-30-2013, 06:04 PM
Punishher7's Avatar
Is it coming from the outer primary cover gasket? That has got to be frustrating.
2013 RGC
Punishher7 is offline
post #5 of 22 (permalink) Old 09-30-2013, 07:10 PM
sj01fltri's Avatar
what color is the oil,what brand of trans fluid are you running,could be a main shaft seal leaking
sj01fltri is offline
post #6 of 22 (permalink) Old 09-30-2013, 10:17 PM
JacktheBagger's Avatar
check yer primary drain plug ??
JtB
2011 Ultra
JacktheBagger is offline
post #7 of 22 (permalink) Old 09-30-2013, 10:25 PM
EdY39's Avatar
Thoroughly clean the inner/outer primary and everything else under there. Buy a can of spray-on baby powder and spray it on all the suspect areas, then go for a decent ride. When you get home, a good look with a flashlight should tell you where it's coming from.
Ed
2002 RoadGlide
DPCM, USN (Retired)
EdY39 is offline
post #8 of 22 (permalink) Old 10-01-2013, 08:17 AM Thread Starter
Admin
BillyBob's Avatar
[QUOTE=Punishher7;1084450]Is it coming from the outer primary cover gasket? That has got to be frustrating.
Yes it looks like it.
BillyBob is offline
post #9 of 22 (permalink) Old 10-01-2013, 08:18 AM Thread Starter
Admin
BillyBob's Avatar
Originally Posted by EdY39 View Post
Thoroughly clean the inner/outer primary and everything else under there. Buy a can of spray-on baby powder and go for a decent ride. When you get home, a good look with a flashlight should tell you where it's coming from.
Will give that a shot. Thanks
BillyBob is offline
post #10 of 22 (permalink) Old 10-01-2013, 08:43 AM
It probably coming off the shifter shaft seal or tranny main shaft seal. It will run down the back of the primary so that it seems like it's the primary but rarely is it from there. Seen this many many times.
HogPro is offline
Oil Leak? Primary Leak? shutzund Troubleshooting for Road Glides 4 06-04-2013 07:55 PM
Oil filter leak -FYI jupiter *General Road Glide Discussions/Pictures 8 07-22-2012 01:47 PM
Only 150 miles OIL LEAK philmartin *General Road Glide Discussions/Pictures 20 03-26-2012 10:13 AM
possible oil leak Roadglide Mike *General Road Glide Discussions/Pictures 2 03-20-2011 03:49 PM
Oil Leak from Stator Wiring? jcanrun *General Road Glide Discussions/Pictures 8 01-06-2011 02:15 PM
