Brake chatter on 21" wheel - Road Glide Forums
post #1 of 10 (permalink) Old 06-20-2011, 02:01 PM Thread Starter
watsondog's Avatar
I had a 21" Colorado Custom put on from day one on my new 11 RGC but the damn thing chatters when the brakes are applied and isnt smooth at all. almost like the rotors are warped...I tried slightly dragging then at higher speeds for a while thinking it was a pad seating issue it seems to help for only a little while . I called th wheel MFG and said to have my shop ck out the rotors see if they are true....
I did lower the front end 1" to copensate for the wheel size.
Does anyone have any ideas for me? I have an appointment this Friday for some other work I will have my tech check it then......
"Let me know how that works out for you"
2011 103" RGC
Reinhart Extreme Duals
S.E. Street Tuner
21" Colorado Custom Slammer 5
Mean City heated seat
Yafee 10" bars
Cams & Dyno soon to come
watsondog is offline
post #2 of 10 (permalink) Old 06-20-2011, 07:10 PM
BostonPhil's Avatar
Mine squeaks, but no chatter, smooth until I stop, but at 5-10 mph to stop it squeaks like crazy. So I've been using the front brake until 10-15mph and then the rear to stop until it breaks in... only 300 miles on the bike since the wheel install, and most of it highway driving with no use of the brake.
L. Phil Chartier
2011 RGC Sedona Orange
- CycleVisions +2 Bars w/PM Elite Grips/Ness mirrors
- Sinister Stretched bags w/ Cycle Sounds 6"x9" Lids
- BADDAD fender w/ custom lighting
- HID headlights & directional delete
- Sony DSX-MS60 w/ 2 WetSounds SYNMICRO amps, Hertz HSK-165XL & Hertz HXC-690
- Corbin Solo seat
- SMW 21" contrast cut Legend front wheel
BostonPhil is offline
post #3 of 10 (permalink) Old 06-20-2011, 10:35 PM
ScooterDog's Avatar
Are you running 1-piece stainless rotors? I've had two sets warp on me. It only takes a little warpage to feel on these bikes. The first set took 6,000 miles, the second set warped in 300 miles. I'm using floating rotors now with no warpage yet. Oh, and I switched to better pads.
'09 RG - All my mods are listed in my "albums"
ScooterDog is offline
post #4 of 10 (permalink) Old 06-21-2011, 12:34 PM Thread Starter
watsondog's Avatar
Thanks Scooterdog & Bostonphil, I will have them ck the rotors this Friday what pads did you change to?
There is no reason a guy should have to listen to howling or sqeeking brakes....
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
post #5 of 10 (permalink) Old 06-21-2011, 12:35 PM Thread Starter
watsondog's Avatar
ScooterDog One piece rotors.....
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
post #6 of 10 (permalink) Old 07-11-2011, 09:03 PM
Glidezilla's Avatar
Got a 21" and it does the same thing...
Every week is SharkWeek Beotches!!!!
Glidezilla is offline
post #7 of 10 (permalink) Old 07-11-2011, 09:20 PM
mr4teth's Avatar
I know this is a silly question but did you reuse the stock pads or did you replace them when you installed the new wheel and rotor?
For the record I had the same issue with my 21 ... that I took off!
2010 110 FLTRX
mr4teth is online now
post #8 of 10 (permalink) Old 07-12-2011, 08:10 AM
Bluzmn59's Avatar
I had the same issue with an 18" aftermarket rotor on my old Street Glide (to the point of sending them back and getting new ones) and know of several other people who have had the same issue with other brands. I switched back to Harley floating rotors and they were smooth as silk. Personally, I will never use any rotor other than Harley again.
Life is hard. It's really hard if you're stupid.
1959 FLHF
2007 FLSTSC
2011 FLTRU
Bluzmn59 is offline
post #9 of 10 (permalink) Old 07-12-2011, 09:34 AM Thread Starter
watsondog's Avatar
My tech checked the rotors no problem there, said give it some time if the pads and rotor dont mary with each other after 2k on it send them back, I have had the 21 on since day one..I asked the wheel MFG if I needed diff pads there reply was no....
2011 103" RGC
S.E. Street Tuner
Yafee 10" bars
post #10 of 10 (permalink) Old 07-22-2011, 01:23 AM
19Cobra96's Avatar
I had the same problem. My pads were causing it. I changed the pads to a Kevlar pad. It was recommended by the seller I bought the rotors from. Before i changed the pads, my front brakes would make a bad squealing sound and would kinda "hum" at slow speeds. No i have no problems what so ever. Brakes work great and look even better!
19Cobra96 is offline
013 w/chatter, clanging in clutch lincolnmatthews *General Road Glide Discussions/Pictures 9 10-09-2013 10:56 AM
front end chatter under braking? junk runner jr Suspensions 5 08-17-2012 03:19 PM
CB Chatter -- Educate me. BDMastiff *General Road Glide Discussions/Pictures 26 05-27-2011 08:28 PM
