Loose Front Axle Bolt - Road Glide Forums
post #1 of 14 (permalink) Old 07-01-2011, 10:50 PM Thread Starter
I am new to fixing little things on my bike, I like learning how to do but some projects are just too hard. I recently had upper fork sliders that I had painted installed, tonight I was cleaning the front fork and when I got down to the axle bolt cover of the front wheel I was able to unscrew it by hand? I totally unscrewed it and removed the bolt from the chrome axel bolt cover, I put some blue locktite on it and screwed it back on then tightened real good with a wrench, then I installed the chrome cover and tightened it over the bolt, did I do the right thing? what was the tech in a rush? good thing it didn't unscrew while I was riding, could it have? now that I am paranoid I removed the axle bolt cover on the other side and there is no screw just a round cylinder with two holes, is that right? sorry I am new at this but with stuff like this happening that I paid for next time I would rather do it myself and the right way, thanks for all your help
METIME is offline
post #2 of 14 (permalink) Old 07-01-2011, 11:51 PM
ScooterDog's Avatar
No, it shouldn't loosen up no matter what! If it's torqued properly you shouldn't need loctite either.
Now check the pinch bolts on the bottom...
'09 RG - All my mods are listed in my "albums"
ScooterDog is offline
post #3 of 14 (permalink) Old 07-02-2011, 12:01 AM Thread Starter
thanks for the help, now dont laugh im new at working on my bike, where are the pinch bolts?
METIME is offline
post #4 of 14 (permalink) Old 07-02-2011, 12:06 AM
ScooterDog's Avatar
No laughing here, we all started somewhere. The pinch bolts are the 2 on the under side of the right fork tube. Under the "round cylinder with two holes". They hold the front axle.
post #5 of 14 (permalink) Old 07-02-2011, 12:10 AM
these are in/lbs so don't go horsing them or you will snap them off.
jeff is offline
post #6 of 14 (permalink) Old 07-02-2011, 02:40 PM
Moderator
BLKNCr6's Avatar
METIME...there is no such thing as a bad question, or a stupid one or anything else derogatory question here. I can vouch for the willingness of this forum to help. Ask anything anytime! If ya want, my PM is always available!
ScooterDog and jeff...you are class acts my friends!
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #7 of 14 (permalink) Old 07-02-2011, 07:01 PM
staush's Avatar
I think i'd go find that "tech" and let him have it verbally or physically. Have them go over everything they did. Get yourself a manual and start doing things yourself. That way you know it's done right or your the only one to blame.
staush is offline
post #8 of 14 (permalink) Old 07-02-2011, 07:24 PM
Sancho's Avatar
My manual says the front axle nut torque is 60-65 ft lbs.
Every time, and I mean every time, I take my bike to the dealer they screw something else up. I just had my starter replaced on my 2010 FLTRX because the paint was peeling off. Fixed under Warranty. When I got home I noticed my battery wouldn't charge when hooked up to the charger. For some reason the had disconnected the battery charging connector from the battery. Only time I let them touch my bike is if it's a warranty issue. Staush is right, buy a manual and some torque wrenches. Do it yourself, follow the manual and it will be done right.
Sancho is offline
post #9 of 14 (permalink) Old 07-02-2011, 11:36 PM Thread Starter
Thanks everyone for all the help, amazing that these guys are professionals that get paid for a service and really never do it right! Well im all squared away for now but now my grip on the throttle side has a lot of play left to right? have no idea how to fix it, it has always had a little play left to right but now its a lot, anyone know what the fix is?
METIME is offline
post #10 of 14 (permalink) Old 07-03-2011, 12:04 AM
h-donut's Avatar
if it's just the chrome covers, if I have that right, the directions say to use
black rtv sealant to hold them on, but only about 50% of the coverage area, applied inside the covers, the pinch bolts hold in place... the rtv does most of the work
essentially, I put mine on and felt the pinch bolts were worthless, did my best nothing has moved in 8k miles.
2010 FLTRX- r o a d g l i d e
h-donut is offline
Enforcer Front rotors loose on install Dyna-petey Wheels and Tires 24 10-10-2019 01:58 PM
17' front axle clamp bolt Wheelie Suspensions 6 04-14-2017 07:58 AM
Axle Bolt "backed" Out CSM-H Wheels and Tires 9 03-17-2015 09:14 PM
Front End Feels Loose Tofast4u *General Road Glide Discussions/Pictures 1 04-29-2014 03:34 PM
Front fork axle stud replacement kimmer127 Troubleshooting for Road Glides 0 04-08-2010 06:35 PM
