What torque wrench??? - Road Glide Forums
post #1 of 13 (permalink) Old 08-08-2011, 07:37 PM Thread Starter
wachuko's Avatar
Question What torque wrench???
Folks,
I have 1/2" and 3/8" drive Ft/lbs torque wrenches but I don't have a small inch/lbs torque wrench... this is for the small T27 torx bolts of the primary. What torque wrench are you guys using?? or just using your handmeter??
Thanks!
Ride Safe! Wachuko - 2016 HD Softail Slim S / 2016 Triumph Thruxton R
2014 RK CVO Tribal Orange-Galatic Black (Gone) / 2013 HD Forty-Eight in Ember Red Sunglo (Gone)
wachuko is offline
post #2 of 13 (permalink) Old 08-08-2011, 07:49 PM
ZachB's Avatar
I've always used my "handmeter". I grew around wrenching with may dad being a mechanic. He always told me "tight is tight, too tight is broken". I had every bolt off my motor on my old RK and never broke any. Many cordless drivers have inch lbs settings. The numbers under the chuck that rotate are usually inch lbs. double check the manual if you're unsure.
ZachB is offline
post #3 of 13 (permalink) Old 08-08-2011, 08:05 PM
Radioactive's Avatar
NAPA has a 3/8" drive for $79 that I'm looking at.
Radioactive is offline
post #4 of 13 (permalink) Old 08-08-2011, 10:03 PM
Vettster's Avatar
Craftsman has one that goes down to about 10 in/lbs IIRC.
Be careful when you go to buy one and check the range on it.
I bought a cheapy that I couldn't use because the torque values wouldn't go down low enough.
I had to replace it with the one that met my needs.
Ride Safe,
Vettster
Vettster is offline
post #5 of 13 (permalink) Old 08-08-2011, 11:12 PM Thread Starter
wachuko's Avatar
Cool
The one I see for 79 is a foot/lbs wrench... not an inch/lbs...
Torque Wrench, Micrometer Style Torque Wrench; 1/2"; 10' lbs - 150' lbs
wachuko is offline
post #6 of 13 (permalink) Old 08-08-2011, 11:45 PM Thread Starter
wachuko's Avatar
Smile
I think I found one:
GearWrench 85051 3/8-Inch 25-250-Inch-Pound Drive Micrometer Torque Wrench
wachuko is offline
post #7 of 13 (permalink) Old 08-09-2011, 08:55 AM
I have a 1/4" Proto - 0 - 160 inch pounds and it worth it's weight in gold for the work that I do. I have all three of my torque wrenches calibrated every year by the snap-on truck just to be safe......
twowheel99 is offline
post #8 of 13 (permalink) Old 08-09-2011, 10:28 AM
How much did it set you back?
post #9 of 13 (permalink) Old 08-09-2011, 10:49 AM Thread Starter
wachuko's Avatar
Red face
I can't believe I am sharing this... I started looking in the toolbox... turns out I have a Stanley 3/8" drive torque wrench in inch/lbs... 30-250 inch-lb
Question is... is it any good and can I trust the darn thing??
wachuko is offline
post #10 of 13 (permalink) Old 08-09-2011, 12:05 PM
Man I use to work for a family owned parts store back in the early 70's they carried Proto & S/K, when I bought it they sold stuff to us a cost +10%. I'm thinking back then it cost me around $50, I use to buy allot of tools from my local Snap-On rep and he could check the wrenches right on his truck which in my case he did for free. I always back them off to zero and never drop them onto anything and always wipe them down and return them to there case's and in case of this one it came in a small cardboard box that what yellow in color. I own three torque wrenches:
1 is 1/4", 1 is 3/8', 1 is 1/2" and like I said earlier they are worth there weight in gold to me when working on Harleys......
torque wrench selection Tackdriver Tech Area 23 02-16-2014 05:41 PM
Torque wrench recommendations StriderJim Do-IT-Yourself 17 02-02-2013 11:34 PM
Torque wrench dwighop Do-IT-Yourself 14 11-12-2012 07:22 PM
in.lb. torque wrench Radioactive General Off-Topic Discussions 27 10-03-2011 09:50 PM
Right tool (torque wrench) for the job? Govdog76 Troubleshooting for Road Glides 9 02-16-2011 03:05 PM
