Gutting the Cat - Road Glide Forums
 4Likes
post #1 of 73 (permalink) Old 08-19-2011, 07:08 AM Thread Starter
Gutting the Cat
Has any one gutted the cat? I have a guy in town that is gutting them and he says it sounds great and gives it more power with out hurting the bike. I currently have 4" reinhardt slip ones and I am thinking of doing this instead of getting new headers. The shop that does this said it works as good as true duels. any thoughts. Thanks!!!
fosterp is offline
post #2 of 73 (permalink) Old 08-19-2011, 07:17 AM
Gonekat's Avatar
ive been considering this as well. I know it will cut down on heat significantly. I also have heard it will change the exhaust note.. Let me know how you make out. I may do mine this winter.
Gonekat is offline
post #3 of 73 (permalink) Old 08-19-2011, 08:26 AM
Moderator
BLKNCr6's Avatar
There is just the problem...real or perceived of the o2 sensors crosstalking. I do believe that a cat gutted stock headpipe allows the o2 sensors to crosstalk, and kinda defeats the whole purpose.
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #4 of 73 (permalink) Old 08-19-2011, 11:26 AM
flhr95's Avatar
Sounds like a good mod as long as you are running the PCV that does not use the 02 sensors.
2010 Fltrx 96", Ness Stage 1 air set-up, V&H Power Duals with Hi Output Slip ons, PCV, SE204 Cams.
flhr95 is offline
post #5 of 73 (permalink) Old 08-19-2011, 04:17 PM
BklynRGU's Avatar
ok guy i have a 2011 rgu and i just cut my cat out.2010 and 2011 02 sensors are before the cat so if there is a cat or no cat 02 sensors doesnt pick this up.the heat issue there isnt anymore,there is a louder tone not much but eough to know and the performace its not alot but you will notice it.
now what im doing is im putting 3.5 rineharts slipons,fuelmoto air filter and im putting a fuel pak.the only reason im doing the air filter,and fuel pak is because i got them before gutting the cat.so if you dont want to spend the extra cash dont you wont need it unless you want to add alittle more horse power.i will try to get soume sound bit over the weekend before and after.
2016 RGS
2011 rgu brillant silver-sold
BklynRGU is offline
post #6 of 73 (permalink) Old 08-21-2011, 09:42 AM
Moderator
BLKNCr6's Avatar
I don't profess to fully understand this phenomena, but people that make their living understanding it say that there is a reversion (negative pulse wave) that gets stopped by the cat...and when the cat is gone, it allows the o2 sensors to cross talk. Seems like the need about 6" of pipe to stop the wave if the pipes are open.
I would guess Jamie at Fuel Moto could give us the real scoop on this...and probably a solution...
It would be fun to see if it's true, but might be like one of those "oil threads" where everyone has a different opinion... Lots of people have gutted the cat, and see no problems...
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
BLKNCr6 is offline
post #7 of 73 (permalink) Old 08-21-2011, 09:46 AM
tdkkart's Avatar
Somewhere I saw a dyno chart comparing with and without, about 2HP was all.
There is a difference in sound though.
tdkkart is offline
post #8 of 73 (permalink) Old 08-21-2011, 10:06 AM
Moderator
BLKNCr6's Avatar
And a difference in right leg heat too.
Sent from my SCH-I400 using Tapatalk
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
BLKNCr6 is offline
post #9 of 73 (permalink) Old 08-21-2011, 06:28 PM
BklynRGU's Avatar
ok guys here it is before and after sound click on the pic for video to play
this was taken with my phone not so great but rineharts sound better
this is stock mufflers w/headpipe gutted (no cats)
stock ecm,and air filter
this is 3.5 rineharts with stock headpipe (no cats)
and stock ecm,and air filter
2016 RGS
BklynRGU is offline
post #10 of 73 (permalink) Old 08-21-2011, 08:15 PM
American customs dose it I'v been running them all summer much cooler
Whitehairedpete is offline
Gutting Factory Head Pipes? FLTRXS20 Intake and Exhaust 7 08-27-2017 08:34 AM
True Header vs Gutting stock pipe ? BadKarma1701 Intake and Exhaust 3 12-16-2016 09:17 PM
Gutting rear tail light for powder LUCKY13 Do-IT-Yourself 4 01-03-2016 09:37 PM
Questions about gutting the cat??? Lee2012fltru Intake and Exhaust 5 05-21-2013 08:05 AM
question gutting the cat SquirtRGU Intake and Exhaust 11 10-23-2011 12:04 PM
