Gutting Factory Head Pipes? - Road Glide Forums
  • 1 Post By Dice21
post #1 of 8 (permalink) Old 08-25-2017, 09:12 AM Thread Starter
I live in Florida and get caught in traffic, stop and go, so the rear cylinder does not shut down for very long. The rear upper exhaust gets hot enough that a couple of times I had to pull over and shut the bike off, it was extremely hot on my right upper leg.
My bike is a 15 Road Glide Special, with stage 1 air breather setup and HD download. The exhaust is factory and I want to keep it that way. I can gut the stock header pipes and leave the rest of the exhaust system stock. How much louder will the exhaust be with it gutted? I believe I will need to install a tuner to ensure the bike does not run too lean. This is all I want to do, as I am happy with the way stock exhaust sounds.
I understand that gutting the exhaust is not hard, as the CAT is in the upper part of the exhaust header, is that correct? Or have I totally misunderstood about gutting the CAT? Also, am I correct in needing a tuner and if so, what are my best options for ease of install and setup on a tuner?
Thanks for any input
FLTRXS20 is offline
post #2 of 8 (permalink) Old 08-25-2017, 10:15 AM
Dice21's Avatar
I did it on my 15 SG. I actually bought my pipe gutted off eBay. Super cheap, and the only downtime was the pipe swap. You will definitely want a tuner. FP3 is the best and easiest in my opinion. Huge reduction in heat, better sound. You won't regret it if you do it.
Swomack likes this.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #3 of 8 (permalink) Old 08-25-2017, 11:59 AM
moto.rich's Avatar
I have stock head pipes that have no cat. I like them.
I also bought 12 mm bungs from amazon and relocated the o2 sensor bung locations further up the head pipe.
2016 RG, 103 HO.
OIF | OEF Combat Infantryman '05 | '07 | '09
moto.rich is offline
post #4 of 8 (permalink) Old 08-26-2017, 04:39 AM
Do I need a open air filter with no cat headpipe (I want buy Jackpot), stock pipes and a PV? There is a video of different sound?
dav.elis is offline
post #5 of 8 (permalink) Old 08-26-2017, 11:16 AM
moto.rich's Avatar
I have the stock air cleaner, but if you go with an open air cleaner you will need a fuel management system.
It'll be louder, but it also depends on the mufflers you have.
2016 RG, 103 HO.
post #6 of 8 (permalink) Old 08-27-2017, 07:23 AM Thread Starter
Gutting factory head pipes
All, thanks for the replies.
FLTRXS20 is offline
post #7 of 8 (permalink) Old 08-27-2017, 07:56 AM
beatlesfab4fan's Avatar
A relatively cheap option is the American Custom Exhaust PowerFlex headpipe Harley Header pipes
Its a couple of hundred and you keep the factory headpipe(in case something happens and you need it) and uses the factory heat shields. Its not full blown obnoxious, but it gives a nice bark when you jump on it.
Mike
beatlesfab4fan is offline
post #8 of 8 (permalink) Old 08-27-2017, 08:34 AM
RFG7680's Avatar
I'll bet the factory download was the bigger culprit. I had that don't on my 05 and it ran so hot my pipes turned orange.
I have a gutted headpipe on my 16. But I didn't do that for heat. I did it for sound. I put the VH FP3 on my bike before any exhaust mods and it cooled it right down. Also changed the throttle response. What a difference.
I just recently swapped out my stock intake for the heavy breather. So I ran the open cat with the CVO mufflers with the 2" fullsac baffles for about 8000 miles with a stock air cleaner. I had an occasional pop on decel which is completely gone with the new intake.
RFG7680 is online now
Gutting the Cat fosterp Intake and Exhaust 72 11-25-2019 03:02 PM
True Header vs Gutting stock pipe ? BadKarma1701 Intake and Exhaust 3 12-16-2016 09:17 PM
Gutting rear tail light for powder LUCKY13 Do-IT-Yourself 4 01-03-2016 09:37 PM
Questions about gutting the cat??? Lee2012fltru Intake and Exhaust 5 05-21-2013 08:05 AM
question gutting the cat SquirtRGU Intake and Exhaust 11 10-23-2011 12:04 PM
