58mm Throttle bodies - Road Glide Forums
  • 1 Post By HeatWave
post #1 of 3 (permalink) Old 09-08-2017, 11:56 AM Thread Starter
Thermodyne's Avatar
Anyone running 58mm throttle bodies on 110's? Looking for pros and cons, S&S vs SE, or any other recommendations.
Got a crank going out on my 103, so am looking at replacing it with a T111 from S&S. And can go with either S&S or SE for a larger 58mm throttle body. The SE costs less and is easier to have in hand, as in no ship away and wait for return. Not that time is much of an issue. The SE also comes with new steppers and TPS. The S&S uses my 40K mile parts unless I supply a new core @$175.
Thermodyne is offline
post #2 of 3 (permalink) Old 09-08-2017, 01:08 PM
For a T-111 I'd definitely go with the SE 58, easier, cost effective, more than adequate...
RGKen likes this.
HeatWave is offline
post #3 of 3 (permalink) Old 09-09-2017, 09:39 PM
Stick_FSMC's Avatar
I've got the SE 58mm on my 110. No trouble with it with +70k miles on it. I have run both the SE255 & SE259E cams.
Stick
USAF 1980-84
Stick_FSMC is offline
PB now has 58mm Throttle bodies for Upgrades raddad Precision Billet Products 0 10-14-2015 07:41 PM
HD SE 58mm Throttle Body ironmark Parts for Sale 11 02-10-2014 11:50 AM
Took Off 58mm Throttle body and put stock 50mm back on ironmark Intake and Exhaust 10 04-19-2013 12:06 PM
Porting stock throttle bodies Glen66 Engine Related 2 08-29-2012 12:10 AM
