M8 RGS Intake - Road Glide Forums
post #1 of 5 (permalink) Old 01-18-2018, 10:29 PM Thread Starter
Bigwoody767's Avatar
M8 RGS Intake
Does anyone know if there is a replacement K&N that can be installed in place of the OEM filter using existing filter housing
Bigwoody767 is offline
post #2 of 5 (permalink) Old 01-18-2018, 10:33 PM Thread Starter
K&n hd1717
Found it. K&N HD1717. Ill leave this up just in case anyone else interested.
post #3 of 5 (permalink) Old 01-18-2018, 11:54 PM
dbraga's Avatar
yup and it works perfect. I have it on mine. Took 5 mins to install. Tops.
dbraga is offline
post #4 of 5 (permalink) Old 01-19-2018, 12:16 AM
georgec's Avatar
What is the benefit of this air cleaner? Does it flow better? Would it require a tuner?
georgec is offline
post #5 of 5 (permalink) Old 01-19-2018, 01:18 AM Thread Starter
@ Georgec - I believe that if you only do slipons or the air filter no tune required. If you do both the slipons and inlet a tuner will be needed as you will be running to lean. benefit is that with this mod you will no doubt follow with pipes and to get better performance you need more fuel thus more air.
Most bikes are set quite lean from factory, by allowing more air in you are just leaning it out further.
Oil leak from AN intake on M8 Matthew04833 Intake and Exhaust 18 10-28-2019 01:25 PM
M8 RG Ultra or M8 RG Special Lu *General Road Glide Discussions/Pictures 15 06-17-2018 11:57 AM
Intake for 2017 RGS Markb1418 Intake and Exhaust 0 07-06-2017 07:45 PM
New M8 RGS InlineR New Members Welcome Area 20 10-01-2016 12:06 AM
WTT: Arlen Ness Double Barrel Intake For Your Intake BadDadFLTR Wanted! (Buy or Trade) 2 08-27-2012 10:12 PM
