Street Cannon Baffles - Road Glide Forums
post #1 of 5 (permalink) Old 04-16-2018, 03:24 PM Thread Starter
What is the description of the tool used to remove the baffles from the 4.5 in Screaming Eagle Exhaust?
Kuzz19 is offline
post #2 of 5 (permalink) Old 04-16-2018, 04:24 PM
geo8866's Avatar
Is there actually a tool specifically for designed for removing Baffles?
geo8866 is offline
post #3 of 5 (permalink) Old 04-16-2018, 06:01 PM Thread Starter
When you look into the end of the pipe there are 3 fasteners that look similar to safety torx bits except
the center post is square and seems to have no teeth on the outer circumference.
Kuzz19 is offline
post #4 of 5 (permalink) Old 04-16-2018, 11:46 PM
rydin2's Avatar
Those just allow you to change the cosmetic ends. I believe the actual baffles are tightly welded in place. I think I have seen a video of someone using a cutting torch, grinder and vise grips to remove them though.....
rydin2 is online now
post #5 of 5 (permalink) Old 04-17-2018, 08:25 AM Thread Starter
I saw the same video but these have a different design. After looking at the cutaway in the Harley parts book I see that on the HighFlow Screaming Eagle Exhaust the catalytic converters are moved to the slip ons and seems to be connected to the baffle.
Kuzz19 is offline
M8 street cannon volume madmat Intake and Exhaust 3 05-28-2017 07:50 PM
Screaming eagle street cannon with end caps Pacman Sold 1 01-10-2016 08:40 PM
Daytona Twin Tec Gen 6 Fully Programmable ECM and Street Cannon mufflers w/ End Caps tgorbett Parts for Sale 1 01-06-2016 07:22 PM
Street Cannon mufflers Skylo Intake and Exhaust 10 01-22-2015 12:00 AM
Check Engine Light on After HD SE Street Cannon Exhaust Installation RicoGlide Troubleshooting for Road Glides 5 04-02-2014 09:09 AM
