Question on True Duals. - Road Glide Forums
 2Likes
  • 2 Post By Lord Vader
post #1 of 4 (permalink) Old 04-23-2018, 03:42 PM Thread Starter
HawaiianBuddha69's Avatar
Aloha Everybody,
HawaiianBuddha69 here. I have 2016 Road Glide and I want to make it True duels. I heard if I put the duels on I will have not c02 sensors and my ideal will be high as I am sitting at a stop and it will come back down in a few seconds..
Has Anybody have or know what I need to do to make my exhaust work.
Thank you,
HB69
Hawaiian Buddha
808 Style
HawaiianBuddha69 is offline
post #2 of 4 (permalink) Old 04-23-2018, 04:28 PM
Bruckus's Avatar
I am running Drago's true duals and still run oxygen sensors. I am no expert, which some on here are, but you have an efi bike and will be running sensors. Depending on your tuner they may be a different size than stock tho. I am running a Thundermax and i believe the sensors were a different size. True duals did not effect my idle but that will be controlled through your ECM/Tuner. You will probably be required to put some sort of tuner on with a true dual conversion or at the least a re-map. There are some much more knowledgeable people here that are sure to chime in.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Bruckus is offline
post #3 of 4 (permalink) Old 04-23-2018, 06:56 PM
any header for your year bike will be tapped for sensors-put the system that you want on and take to the dealer-they will do a flash tune for about 100.00
diesel5 is offline
post #4 of 4 (permalink) Old 04-23-2018, 08:23 PM
Lord Vader's Avatar
The new pipes will have plugged holes where the O2 sensors go. Get yourself a heavy breather hi flow air cleaner at the same time and then get it tuned. A true duel without an new AC is a waste of money. The bike needs to breathe.
08Zinc and Jwams like this.
JOIN THE DARK SIDE
Lord Vader is offline
Factory duals or true duals Diverrick Intake and Exhaust 14 01-24-2016 02:47 PM
True duals or power duals LUCKY13 Intake and Exhaust 16 01-11-2016 09:44 PM
Rinehart true duals 4" or V&H dresser duals with monster rounds iambill Intake and Exhaust 5 10-18-2014 08:49 AM
True definition of true duals? cypress Intake and Exhaust 8 06-23-2012 10:22 PM
Thunderheader true duals/MGS true duals JKRSDETROIT Intake and Exhaust 2 03-26-2012 01:06 PM
