True Dual With Rear Pipe Exit Left Side - Road Glide Forums
post #1 of 8 (permalink) Old 09-06-2018, 11:01 AM Thread Starter
Hi. I've got a '17 FLTRU I'd like to outfit with a true dual exhaust where the rear cylinder pipe exits immediately to the left side of the bike. This is so much nicer looking than the current style (Bassani etc) which exits on the right, joins with the front cylinder, and then goes under the right side of the bike. Samson makes the nicer true dual design but only for older softtails it looks like. I understand there are disadvantages, extra heat when a pipe has to bend immediately, and the cylinders don't share back pressure (slight power advantage). But if nobody is going to make this for the M8 I might have to have it fabricated when it goes off warranty, which ain't going to be cheap. It seems like someone will make this eventually but the M8 has been out now for two years ....
Rberger is offline
post #2 of 8 (permalink) Old 09-06-2018, 01:49 PM
James's Avatar
I think 08 was the last year of the duals you are looking for. That's how mine are, exits the left side. If you are looking at fabbing some, it might be advantageous to start with a used set from an older bike and weld in your stock flanges. I have seen some sets floating around fairly cheap.
James is offline
post #3 of 8 (permalink) Old 09-06-2018, 05:59 PM Thread Starter
Thanks James. I can't figure why nobody is making it they look so much better.
Rberger is offline
post #4 of 8 (permalink) Old 09-06-2018, 08:14 PM
Your don’t need to weld on your flanges. They all use snap rings to retain the flange on the headpipe. As long as you have the short, larger step right at the end that stops the snap rings from sliding right off, your good. If I remember contractor, M8, twin cam and evo use the same size flange anyways, so it might be a moot point.
In any case, you might be further ahead to find a used exhaust system on Craigslist or eBay and start cutting where you need. Then at least you are starting with some bends and can get closer than starting with straight tubing. I’ve made a number of exhaust pipes for bikes over the years like that.
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
post #5 of 8 (permalink) Old 09-06-2018, 08:28 PM
MightyWhitey's Avatar
08??? I thought you had one of those funky looking Benders?
MightyWhitey is offline
post #6 of 8 (permalink) Old 09-06-2018, 09:15 PM
James's Avatar
‘08??? I thought you had one of those funky looking Benders?
No Sir.
Bonus points for including the exhaust OP is wanting.
Maybe this link will work. Feel free to post it if you want.
http://flic.kr/p/HxJK6i
James is offline
post #7 of 8 (permalink) Old 09-06-2018, 09:17 PM
James's Avatar
I am really starting to get pissed at this site. Every damn time the view is different and it won't let me post the pic. I will put it on flikr and try again.
James is offline
post #8 of 8 (permalink) Old 09-06-2018, 10:13 PM
Daaayuum Son! Sexy! Thanks for the bike porn.
Python 2-1 Side Exit Chrome Exhaust TLKurtz Parts for Sale 8 09-14-2015 04:33 PM
side exit exhaust 1badglide3 Parts for Sale 6 04-23-2015 04:07 PM
WTB a 2 into 1 or side exit exhaust for 07 bagger davesnider Wanted! (Buy or Trade) 2 03-12-2014 03:15 PM
Side exit exhaust WHCIV Intake and Exhaust 7 02-27-2014 07:23 PM
side exit exhaust options CustomGlide Intake and Exhaust 13 10-14-2012 02:43 AM
