catalytic converter - Road Glide Forums
 6Likes
post #1 of 21 (permalink) Old 10-09-2018, 09:10 AM Thread Starter
staush's Avatar
catalytic converter
Question for anyone who has removed their cat. or replaced a header without a cat. Does removing the cat increase the exhaust sound level even with stock mufflers? On my Freewheeler it has Jackpot 2-1-2-headers without the cat and the exhaust is LOUD.Is this normal?
staush is offline
post #2 of 21 (permalink) Old 10-09-2018, 12:02 PM
Dice21's Avatar
Depends on the bike. A Twinkie, definitely does. An M8, doesn't do squat. I gutted the stock header on both. Great sound on the 103. Nada on the M8.
11" Road6 bars. Hell's Foundry hidden fairing supports. Bad Dad bags. S&S air Stealth air cleaner. FP3. Custom Dynamics lights. Memphis Shades windshield. Decatted head pipe. Tab Slipons w/Zombie baffles. B52 w/ ARC 602's
Dice21 is offline
post #3 of 21 (permalink) Old 10-09-2018, 07:57 PM
It made mine louder, especially when you roll on the throttle .
RGKen likes this.
post #4 of 21 (permalink) Old 10-09-2018, 08:17 PM
madmat's Avatar
Yes this ^^^^^^^^
18 RGS Bonneville Salt Pearl
madmat is online now
post #5 of 21 (permalink) Old 10-22-2018, 03:12 PM
Craig&Candy2013's Avatar
Remove Cat
Whats the best way to remove the cat
Craig&Candy2013 is offline
post #6 of 21 (permalink) Old 10-22-2018, 08:44 PM
I don't know about best ,but I cut the pipe in half right in the middle of the cat. Then used a hole saw and carbide burr cutter to remove the rest on the inside of the pipe and welded it back together.
Others have cut a window out ,the size of the cat on the inside of the pipe.
post #7 of 21 (permalink) Old 10-22-2018, 09:13 PM
PBSTN's Avatar
I cut the pipe in half. At the front of the cat. Basically where the factory weld is. Put it in a vise. Drill holes all aound down thru the cat (on the sides). Then use plyers and pull the center chunk out. Then chisel the sides smooth. Weld it back up. When it's on the bike with the heat shield. It's hard to notice the weld.
2001 FLHR-Traded. 2010 FLTRX-Sold.
2010 FLHR
2003 FLHRSEI2
PBSTN is offline
post #8 of 21 (permalink) Old 10-26-2018, 11:12 AM
Glide08's Avatar
You can also buy completely gutted headpipes on ebay for 150.00 I bought one they gutted it without cutting it don't know how but it was CLEAN. When I trade my bike cat pipe goes back on switch out new one.
Glide08 is offline
post #9 of 21 (permalink) Old 10-26-2018, 11:38 AM
jcarruth's Avatar
I haven't seen dyno #s lately, but from what I have read over the last two years, removing the cat does little to increase flow or add performance. What it does do is decrease heat and maybe improve sound. A lot depends on what else you have done to the bike.
Right now, my '17 RGS only has V&H HOs, stock headers with cat, stock air, and a warranty.
Runs and sounds great. Head temp a little elevated, not much, can't remember the #s. No backfires, popping, any of that.
At two years, gonna add a PV to richen up the fuel/air mix. May and add either a K&N or a Big Sucker, someday. Stock AF flows plenty of air for what I need.
2017 HD Road Glide Special
jcarruth is offline
post #10 of 21 (permalink) Old 10-26-2018, 01:51 PM
Glide08's Avatar
Agree I don't think it did much if any for sound but I did it for heat and it did help there and I'm running stage 2 cam and cannons
Glide08 is offline
Catalytic converter removal bfore Intake and Exhaust 12 09-22-2016 07:09 AM
Stock Header pipe " no catalytic converter " Toecutter Parts for Sale 1 10-30-2013 05:51 PM
Catalytic Converter intro. grambo Intake and Exhaust 7 10-10-2013 06:15 PM
Catalytic converter removed MACM2003 ECM/Fuel Management systems 19 07-20-2012 08:36 AM
Catalytic converter jimchapp New Members Welcome Area 14 02-22-2012 06:07 PM
